| wayne1234 |
Apr 27 2009, 07:23 PM
Member ![]() ![]() Group: Members Posts: 260 Joined: 6-April 09 From: indianapolis in Member No.: 10,238 Region Association: None |
OK, I have a fairly new Lincoln 175hd welder, it is 220volt I have have not done a ton of welding but enough to to be dumb I guess. what I have welded in the past is 1/4" thick metal like a totally fabbed snow plow mount for my ram truck. shortened and welded a steel flatbed(thinner metal for top , diamond plate) to same truck. various trailer repairs. and such.,,, so my new to me 914 needs a few welds like in the front trunk where the previous owner did as trunk patch. I start by filling in a couple of small screw holes, that goes fine, then I tried the seam and it seems like I am blowing right through the metal. or it keeps puddling like a drip below.? and forget trying to fill a small gap..... Now let me say I am using FLUX CORED WIRE. with no gas. (I haven't ever used gas) is that my problem? did I just get away with it in my thicker metal? I know a buddy told me flux-cored gets more penetration. this is the first "sheet metal" welding I have done. Any input is welcome.
| wayne1234 |
Apr 27 2009, 08:00 PM
This is how puzzled I was... I looked at the manual,,, is is on the lowest power setting and the feed rate is 2.5-3 (which the manual suggested) , what is puzzling is that at a faster feed rate. (which I was at first) it seemed to eat away the metal faster ? seemed backwards to me. I was able to close a 1/4" bolt hole, but the the drip on the underside is like 1/2" long!!!I did this by welding a little then letting it cool (15 seconds) not red then hit it again for a second or two. and so on . has anyone had any success with flux cored wire?
| CliffBraun |
Apr 27 2009, 08:09 PM
Member ![]() ![]() Group: Members Posts: 252 Joined: 26-April 06 From: San Luis Obispo,ca Member No.: 5,933 Region Association: None |
This is how puzzled I was... I looked at the manual,,, is is on the lowest power setting and the feed rate is 2.5-3 (which the manual suggested) , what is puzzling is that at a faster feed rate. (which I was at first) it seemed to eat away the metal faster ? seemed backwards to me. I was able to close a 1/4" bolt hole, but the the drip on the underside is like 1/2" long!!!I did this by welding a little then letting it cool (15 seconds) not red then hit it again for a second or two. and so on . has anyone had any success with flux cored wire? If you read my post the amount of energy you put in is proportional to feed rate and voltage setting. I'd suggest dropping the feed rate and welding in bursts. I'm not sure about the effect of using thinner wire, but I think it might work better. Edit: Some of the most fun I had welding was with FCAW and a shielding gas, Spray welding is bitchin'. |
wayne1234 help from welding guys, having trouble with mig flux cored wire Apr 27 2009, 07:23 PM
Spoke I believe the flux cored wire is relatively heavy ... Apr 27 2009, 07:34 PM
CliffBraun I'd try shorter welding cycles, maybe a lower ... Apr 27 2009, 07:39 PM
charliew The only flux cored wire I ever used was stick wel... Apr 27 2009, 08:06 PM
rdr
The only flux cored wire I ever used was stick we... Apr 27 2009, 08:13 PM
dlo914 I did this with a flux core welder, i pretty much ... Apr 27 2009, 08:58 PM
rjames
:agree:
It will make things MUCH easier for y... Apr 28 2009, 09:19 AM
Vacca Rabite I did my entire care with flux core as I could not... Apr 28 2009, 10:57 AM
9146986 Get the shielding gas kit for that welder, and use... Apr 28 2009, 11:51 AM
charliew The jist is yes you can learn to "get by... Apr 28 2009, 12:45 PM![]() ![]() |
Lo-Fi Version | Time is now: 4th November 2026 - 09:00 AM |
