> New Webers on 914 - one port emmitinig fuel, HELP
Downerman
post Apr 25 2009, 01:49 PM
Just got the new dual weber kit (40 IDF) and it's all in. Presure regulator, fuel pump, it's all in (have not started it yet) but I have a problem. One of the ports is loading up with fuel. I pulled the top and the float was working (the other port was not emitting fuel after the float reached the top. Took drivers side carb off. Setup on the trunk lid with lot's of towels and turned the key on. Like I said all the other three ports stop however this one keeps dripping fuel. I am lost and not knowing exactly what these screws do (other than the idle) I really am scared to start turning them. Why would one port emmit fuel and not the other when they share the float?
Any suggestions guys?
jmill
post Apr 28 2009, 07:02 AM
Green Hornet
Sounds like its coming out of the progression ports. Fuel should only flow from there when you transition from the idle jets to the mains. The butterfly position determines whether or not your pulling a vacuum on the ports.
- Lo-Fi Version Time is now: 4th June 2025 - 03:00 AM
