> 23mm MC plumbing question
Qarl
post Jan 30 2004, 11:34 PM
Shriveled member
I will be installing a 23mm MC to feed the bigger brakes on the new car. I have heard that their are plumbing issues, and clearance issues when installing the bigger MC.
I'm looking for feedback from those that have done this.
Here is a comparison of the new and old MC. I have some questions.
1) Ports 3 and 4 are the front and rear output ports. These correspond (location-wise) to ports 1 and two on the new MC. It seems that I can just transfer the hardware and lines over without any issues. Correct?
2) The locations of the feed lines are different between new and old. Is this going to be a clearance issue?
3) The hydraulic pressure switch (located between ports 3 and 4) does not have a corresponding location on the NEW MC. But there is another output port on the bottom of the MC (underneath port 1) that I can use? Any clearance issus here?
4) Does anyone know what the bolt on the top of the NEW MC is for? (between the red caps)... If I remove it, will a genie come out and grant me 3 wishes?
These would be easier to answer if my car body were in the same location as my parts. (hopefully in a couple of weeks!)
Thanks!
Qarl
post Jan 31 2004, 09:42 AM
Shriveled member
Ducts are a 911 piece from AJUSA also available from SmartRacing.
The 23mm vs 19mm is sort of a tie. Either/or
If there would be a 21mm MC, then it would be perfect, or so I have been told!
Qarl   23mm MC plumbing question   Jan 30 2004, 11:34 PM
0396   kellzey, I'll let you know,as Brad suppose to...   Jan 31 2004, 07:07 AM
seanery   Karl, are you using boxster or 944turbo fronts? Le...   Jan 31 2004, 07:09 AM
0396   I have a set of big reds 993 turbo on all fours.   Jan 31 2004, 07:11 AM
ArtechnikA   <...   Jan 31 2004, 07:42 AM
ArtechnikA     Jan 31 2004, 07:47 AM
Qarl   Thanks everyone. The alloy cross member is not a ...   Jan 31 2004, 08:47 AM
echocanyons   Karl, How does the alloy crossmember mount? The s...   Jan 31 2004, 09:33 AM
echocanyons   IS the 23mm MC necessary for the monoblocks? I as...   Jan 31 2004, 09:34 AM
Qarl   Ducts are a 911 piece from AJUSA also available fr...   Jan 31 2004, 09:42 AM
ArtechnikA   <...   Jan 31 2004, 09:58 AM
Jeroen   <...   Feb 1 2004, 04:10 PM
Howard R   Rich, In my case it might have something to do wi...   Feb 1 2004, 05:54 PM
Qarl   Hmmmm.... I think I found an ATE 20.64mm Master Cy...   Feb 1 2004, 07:22 PM
ArtechnikA     Mar 13 2004, 05:31 PM
john rogers   When I bought mine several years ago, it came with...   Mar 13 2004, 09:24 PM
davep   I saw a car today, a converted 73, that had a boos...   Mar 13 2004, 09:53 PM
SirAndy   <...   Mar 14 2004, 03:05 AM
ArtechnikA
- Lo-Fi Version Time is now: 1st July 2025 - 09:41 AM
