> 23mm MC plumbing question
Qarl
post Jan 30 2004, 11:34 PM
Shriveled member
I will be installing a 23mm MC to feed the bigger brakes on the new car. I have heard that their are plumbing issues, and clearance issues when installing the bigger MC.
I'm looking for feedback from those that have done this.
Here is a comparison of the new and old MC. I have some questions.
1) Ports 3 and 4 are the front and rear output ports. These correspond (location-wise) to ports 1 and two on the new MC. It seems that I can just transfer the hardware and lines over without any issues. Correct?
2) The locations of the feed lines are different between new and old. Is this going to be a clearance issue?
3) The hydraulic pressure switch (located between ports 3 and 4) does not have a corresponding location on the NEW MC. But there is another output port on the bottom of the MC (underneath port 1) that I can use? Any clearance issus here?
4) Does anyone know what the bolt on the top of the NEW MC is for? (between the red caps)... If I remove it, will a genie come out and grant me 3 wishes?
These would be easier to answer if my car body were in the same location as my parts. (hopefully in a couple of weeks!)
Thanks!
ArtechnikA
post Jan 31 2004, 09:58 AM
rich herzog
QUOTE(kellzey @ Jan 31 2004, 07:42 AM)
Ducts are a 911 piece from AJUSA also available from SmartRacing.
If there would be a 21mm MC, then it would be perfect, or so I have been told!
are you using the blockoff plates too? i'm planning on using all that same stuff. does the kit come with fasteners to put your hubs back together, or are we on our own for that ?
the aluminum caliper cars came with a 20,55mm MC but those have been NLA for a while, i've been told. if you go to a dealer with one of those cars with a bad MC, i have no idea what they'd replace it with (if you could find a dealer interested in your '71 car these days ...). probably offer to 'upgrade' you to the 19mm for its "superior pedal feel and improved modulation" ... (the "sell what you've got" school of marketing ...
Qarl   23mm MC plumbing question   Jan 30 2004, 11:34 PM
0396   kellzey, I'll let you know,as Brad suppose to...   Jan 31 2004, 07:07 AM
seanery   Karl, are you using boxster or 944turbo fronts? Le...   Jan 31 2004, 07:09 AM
0396   I have a set of big reds 993 turbo on all fours.   Jan 31 2004, 07:11 AM
ArtechnikA   <...   Jan 31 2004, 07:42 AM
ArtechnikA     Jan 31 2004, 07:47 AM
Qarl   Thanks everyone. The alloy cross member is not a ...   Jan 31 2004, 08:47 AM
echocanyons   Karl, How does the alloy crossmember mount? The s...   Jan 31 2004, 09:33 AM
echocanyons   IS the 23mm MC necessary for the monoblocks? I as...   Jan 31 2004, 09:34 AM
Qarl   Ducts are a 911 piece from AJUSA also available fr...   Jan 31 2004, 09:42 AM
ArtechnikA   <...   Jan 31 2004, 09:58 AM
Jeroen   <...   Feb 1 2004, 04:10 PM
Howard R   Rich, In my case it might have something to do wi...   Feb 1 2004, 05:54 PM
Qarl   Hmmmm.... I think I found an ATE 20.64mm Master Cy...   Feb 1 2004, 07:22 PM
ArtechnikA     Mar 13 2004, 05:31 PM
john rogers   When I bought mine several years ago, it came with...   Mar 13 2004, 09:24 PM
davep   I saw a car today, a converted 73, that had a boos...   Mar 13 2004, 09:53 PM
SirAndy   <...   Mar 14 2004, 03:05 AM
ArtechnikA
- Lo-Fi Version Time is now: 1st July 2025 - 01:43 PM
