Great rattle can paint, Krylon |
Randal |
May 6 2009, 02:42 PM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
If you're going to get a rattle can for any paint work, try the new Krylon one with the blue tip. I asked the TS guys at Krylon and they said all cans should now have this tip - as they've been manufacturing nothing else since January.
Anyway, IT PAINTS GREAT! Much bigger pattern, so you don't have to keep going over and over again and setting yourself up for runs. You can also adjust this tip to change your pattern. Haven't tried that yet, but will shortly. http://www.krylon.com/press/press-releases...h-360/index.jsp I've always liked Krylon as it holds up. Also like Rustoleum, but that stuff is, IMHO, very hard to paint, especially on wheels. |
byndbad914 |
May 7 2009, 04:46 PM
shoehorn and some butter - it fits Group: Members Posts: 1,547 Joined: 23-January 06 From: Broomfield, CO Member No.: 5,463 Region Association: None |
can either use a NACA duct in the side of the sail panel, or I have seen more than a couple cars with scoops built on the side of the sails, sticking out but follow the shape of the sail panel pretty well so they don't look out of place, that capture air. Then there is a hole thru the sail panel and ducting on the inside down to the air intake area.
Lo-Fi Version | Time is now: 8th June 2024 - 07:08 AM |
