dbgriffith75 |
TheGrif ![]() ![]() ![]() Group: Members Posts: 509 Joined: 25-July 07 From: Iowa, USA Member No.: 7,945 Region Association: Upper MidWest ![]() |
I don't have anything in particular I'll need to wet sand soon, but I got to thinking about this today and was just wondering.
I've known some people to spray a given area with a hose, then sand. I've known some to wipe down the area with a wet rag, then sand. And one guy I know dips the sandpaper in water, then sands. My personal preference is to wipe down the area with a wet rag, then sand. Just wondering how other guys do it and what could be considered the "best method." (IMG:style_emoticons/default/beerchug.gif) |
sww914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None ![]() |
If it's outside and it's warm I'll use a hose. If it's inside and I don't want a river running through the shop I use a bucket and a rag. If it's just a couple little spots I just dip the paper in a bucket here & there. You can use your hand if you're careful about not making high & low stripes with your fingers, if there's any doubt use a foam block. I always sand the bodylines, edges, and depressions first and then do the flats. That will smooth out any ridges that you made while concentrating on the little surface features.
dw914er |
Planning Cities ![]() ![]() ![]() ![]() Group: Members Posts: 2,365 Joined: 1-March 08 From: Yucaipa, CA Member No.: 8,763 Region Association: Southern California ![]() |
If it's outside and it's warm I'll use a hose. If it's inside and I don't want a river running through the shop I use a bucket and a rag. If it's just a couple little spots I just dip the paper in a bucket here & there. You can use your hand if you're careful about not making high & low stripes with your fingers, if there's any doubt use a foam block. I always sand the bodylines, edges, and depressions first and then do the flats. That will smooth out any ridges that you made while concentrating on the little surface features. (IMG:style_emoticons/default/agree.gif) (he taught me btw, and I used a foam block because it just made it alot easier since I was/am a n00b) |
Lo-Fi Version | Time is now: 11th July 2025 - 08:34 AM |
