nycchef |
mechanical moron ![]() ![]() ![]() Group: Members Posts: 952 Joined: 28-November 05 From: new york city n.y. Member No.: 5,202 Region Association: None ![]() |
73 914 w/ 74 2.0 dual weber 40's. finally sorted out the linkage problem and car starts right up , idles a little rough @ about 1000 rpms. decided to take a little spin before balancing the carbs. no such luck, clutch (which is new) won't engage in any gear, just grinds and the engines revs up to about 2000 when the clutch is dpressed, now i'm depressed. never touched the center tunnel when i switched the engine out, clutch and accellerator cables are the same. could they be croosed or tangled somewhere?
tat2dphreak |
stoya, stoya, stoya ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region ![]() ![]() |
scott beat me to it... I remember this issue popping up quite a few times... once I fixed this on mine, my accel cable started 'hanging' after a full-throttle punch because it got into a bind...
nycchef |
scott beat me to it... I remember this issue popping up quite a few times... once I fixed this on mine, my accel cable started 'hanging' after a full-throttle punch because it got into a bind... i.ll dig into it tonight. new territory for me. damn these cars have some wierd problems (IMG:style_emoticons/default/WTF.gif) |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
scott beat me to it... I remember this issue popping up quite a few times... once I fixed this on mine, my accel cable started 'hanging' after a full-throttle punch because it got into a bind... i.ll dig into it tonight. new territory for me. damn these cars have some wierd problems (IMG:style_emoticons/default/WTF.gif) Ever wonder why so many people can answer certain questions? Well, we have all BTDT... When you replace the throttle cable (the first time) you will also most likely make the same mistake. The fix is simple..seeing in the tunnel is not. The throttle cable does a single loop around the clutch cable.. the fix, as stated above is to remove the throttle cable from the pedal, then, with a mirror, figure out which way you need to unwrap it from the clutch cable... Good luck. RIch |
Lo-Fi Version | Time is now: 3rd July 2025 - 07:57 PM |
