Fuel pump physics, Push/pull/suck/pump? |
lmcchesney |
Feb 3 2004, 06:49 PM
Member Group: Members Posts: 488 Joined: 24-November 03 From: Ocala, Fl. Member No.: 1,381 Region Association: None |
My little fuel pump(72) has been working for six years without a problem. Now that I am rebuilding the car and looked at the fuel hose diagram with fuel flows as per PP and DD, I must admit. I have not the foggest how this little pump works.
Fuel tank supply feeds a "Y" connector with the "R" port on the pump and the fuel line feeding the engine compartment. I do not see a valve in the "Y" connector. Fuel returns from the engine compartment to enter the "S" port. Then the "D"port returns the fuel to the tank. If the roller pump works by pushing fuel out the "R" port, why would the fuel not flow to the engine compartment and back to the tank via the supply line? I have done a search and reviewed the classic section without finidng the answers. What mechanism is being used? Thanks, L. McChesney lamcchesney@netzero.net |
Dave_Darling |
Feb 4 2004, 10:51 AM
S = "Saugen" == German for "suction"
D = "Druck" == German for "pressure" R = "Rückkehr" == German for "return" There is no damper, never has been. The 'D' simply means "pressure", as in "this is the port that supplies fuel at pressure". The Y fitting is in the return line, allowing any excess fuel from the pump to join the fuel that the fuel pressure regulator allows to go back to the tank. Sorry about the drawing being confusing. --DD |
Lo-Fi Version | Time is now: 7th June 2024 - 05:52 AM |
