Car finally runs! Not out of the woods yet., Rough idle problem |
scoobykvn |
Jun 7 2009, 04:13 PM
Member Group: Members Posts: 142 Joined: 6-July 06 From: columbus, ohio Member No.: 6,388 Region Association: Upper MidWest |
So I got my 1970 1.7 still injected finally ready to drive. It starts right up with and runs fine, for about 20 - 30 seconds, then it starts to idle rough. The idle will drop to almost 0 then surge to about 1500 - 2000rpm. If I slowly roll onto the throttle it revs up, but if I quickly press the throttle it stumbles and almost dies then revs up. I am going to get a vacuum gauge soon and check for leaks using the method in Tech Tips 700. Anybody have any ideas of what to look for? Could it be something other than a vacuum leak?. I have done a valve adjustment, replaced points, rotor, cap, plugs, injector seals. Still have not checked timing or dwell. I will also double check the MPS.
scoobykvn |
Jun 7 2009, 09:18 PM
So after it warms up it runs a little better. RPM's not dropping quite as low and not surging quite as high. Also, it does not stumble when I punch the throttle after it is warmed up, but after I punch it the idle drops almost to the point of dying.
Lo-Fi Version | Time is now: 11th June 2024 - 03:15 PM |
