'75-'76 FI Fuel Pump in '74 Location, Any Problems Putting it There?? |
AvalonFal |
Jun 9 2009, 03:09 PM
Member Group: Members Posts: 483 Joined: 3-July 05 From: Southern New Jersey Coast Member No.: 4,367 Region Association: MidAtlantic Region |
I'm going to replace the original '74 3 port fuel pump with a '75-76 2 port model in the original stock location on the body under the R/S engine tin. As long as the flow rate and the operating pressure are sufficient, are there any operational problems putting it there?? How about mounting??
I know these pumps "push" fuel better than suction, but I don't want to relocate it to the front trunk. (I'm also trying to avoid buying a China rebuilt 3 port.) All help appreciated. Paul |
r_towle |
Jun 9 2009, 05:34 PM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
What size is the two port pump inlet hoses?
I recall one of them is some huge size like 12mm or something...I cant remember, but I recall it was not an easy hose to bend without kinking, so It had to be cut the right length. all that blather wont apply to this setup, but the hose size and the need for some adapter would apply... I found a delco pump that was half the price of the Bosch (sorry Capn) pump and it fit perfectly and was at the same specs. The pump, from what I recall, needs to produce 65PSI...that is the original spec. I cant remember the GPH number, but its not small. I went to my local FLAPS and he pulled out the pump book. We looked up the Bosch pump and read the specs, then looked around for others. Volvo, mercedes, and several others used this type of pump. Rich |
Cap'n Krusty |
Jun 9 2009, 05:56 PM
What size is the two port pump inlet hoses? I recall one of them is some huge size like 12mm or something...I cant remember, but I recall it was not an easy hose to bend without kinking, so It had to be cut the right length. all that blather wont apply to this setup, but the hose size and the need for some adapter would apply... I found a delco pump that was half the price of the Bosch (sorry Capn) pump and it fit perfectly and was at the same specs. The pump, from what I recall, needs to produce 65PSI...that is the original spec. I cant remember the GPH number, but its not small. I went to my local FLAPS and he pulled out the pump book. We looked up the Bosch pump and read the specs, then looked around for others. Volvo, mercedes, and several others used this type of pump. Rich The 12 mm line goes from the filter to the pump. The filter uses the same adapter/reducer hose as the earlier filter. The pump outlet is the same size as the outlet of the early 3 port pump. The brackets are the same, too, but you have to remove the push-on electrical connectors from their plug in order to plug in the pump. Where's the difficulty? Yes, there are Delco and other brands of pumps that'll work, and that's OK with me. I just choose to go the easy route, one that I have to do NO research, no shopping, and very little adaptation. The Volvo and Mercedes D jet systems used a similar, if not the same, 3 port pump, and they're equally unavailable. I don't believe either maker used L-jet. The Cap'n |
Lo-Fi Version | Time is now: 11th June 2024 - 01:50 AM |
