Turn key...and nothing |
craig3x |
Jun 11 2009, 06:39 PM
Member Group: Members Posts: 106 Joined: 18-April 09 From: Sacramento Member No.: 10,275 Region Association: None |
I recently aquired a bone stock '75 with a 1.8 and was told it ran great last time it was started 6 months ago. So I charged the battery, turned the key....and nothing. The other electronics work though. I can hear the fuel pump kick on, headlights pop up, horn works, etc.
Does it sound like an ignition switch problem, or a starter problem? Or something else I'm not thinking of? (IMG:style_emoticons/default/WTF.gif) |
Cap'n Krusty |
Jun 11 2009, 07:21 PM
"Some" '75s have the seat belt interlock relay under the passenger seat. If this is one of them, make sure the 2 big yellow wires are bridged. Make sure you have good battery connections, and that the tranny ground strap is good, then jack the car up, chock the front wheels, make sure it's in neutral, and jump from the battery cable post on the solenoid to the tab where the yellow actuator wire is connected. If it cranks when you do that, look to the ignition switch. BTW, whacking on the starter or its solenoid is a BAD idea.
The Cap'n |
Lo-Fi Version | Time is now: 12th June 2024 - 09:17 AM |
