Help! I'm Stymied!, Only firing on #3 and # 4 |
DipShit |
Jun 12 2009, 10:19 AM
Member Group: Members Posts: 199 Joined: 26-May 04 From: Cheyenne, WY Member No.: 2,107 |
1.7 D-Jet
Engine was running just great until about two weeks ago, sigh. Now only fires on # 3 and # 4. I have cleaned every connection including all grounds. And I mean cleaned them good! The elecrical appears to be just fine. I get a good noid light at both # 1 and # 2. The injectors have tested just fine as well (I'm getting about 7cc in 15 seconds). I have 40lbs of pressure the 1,2 rail. The spark plugs are getting juice and fire. I have installed new points, cleaned the triggers (which shouldn't have mattered because of the sequence) and set the dwell. I'm a tad under at 44 degrees, but again shouldn't keep # 1 and # 2 from firing. The timing has to be close as it runs really smooth for just two cylinders. If I pull the power to injector 3 or 4, I get a real good drop and she will die. If I pull 1 or 2 - no change. If I add propane to the intake, I get a good response in higher rpm. I had originally traced to the Temp II sensor and it failed, so I replaced it. A new one seemed to be the fix, but only for a moment. I have good fuel, spark and air - (IMG:style_emoticons/default/WTF.gif) I'm STYMIED (or just a REAL DIPSHIT) |
r_towle |
Jun 12 2009, 05:01 PM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
You are wasting your time if you have not set the valve adjustment correctly and verified that you did not loose a valve seat...(pounded into the head)
Tune ups on these motors start with setting the valves. Then you set the points and verify that with a dwell meter...dont guess. then you set the timing with a timing light...dont guess its right because it purrs...not a valid setting.. The valves and dwell cannot be off in the least or it will run wrong. the timing can be off...it will run ok..it will behave poorly under load. You have not answered any questions regarding the color of the plugs. What plug brand and part number are you using? How old are your plug wires? Cap, Rotor, condensor, coil? Most times the supposed FI issues are ignition related. SET THE VALVES Rich |
Lo-Fi Version | Time is now: 8th June 2024 - 04:17 PM |
