Fuel pump physics, Push/pull/suck/pump? |
lmcchesney |
Feb 3 2004, 06:49 PM
Member Group: Members Posts: 488 Joined: 24-November 03 From: Ocala, Fl. Member No.: 1,381 Region Association: None |
My little fuel pump(72) has been working for six years without a problem. Now that I am rebuilding the car and looked at the fuel hose diagram with fuel flows as per PP and DD, I must admit. I have not the foggest how this little pump works.
Fuel tank supply feeds a "Y" connector with the "R" port on the pump and the fuel line feeding the engine compartment. I do not see a valve in the "Y" connector. Fuel returns from the engine compartment to enter the "S" port. Then the "D"port returns the fuel to the tank. If the roller pump works by pushing fuel out the "R" port, why would the fuel not flow to the engine compartment and back to the tank via the supply line? I have done a search and reviewed the classic section without finidng the answers. What mechanism is being used? Thanks, L. McChesney lamcchesney@netzero.net |
lmcchesney |
Feb 5 2004, 06:24 AM
Thanks all,
Chris, the duel pump is for stable pressure, but will not significantly increase flow. The fuel rails are much larger capacity as well. The theory is that the injected volume being much less than than the rail volume, thus decreasing pressure drop. Theory for now. Thus, there would not be an increased flow rates therefore, same sized feed/return line would not effect flow rates. Thanks, L. McChesney |
Lo-Fi Version | Time is now: 1st June 2024 - 05:53 AM |
