EJP914 |
Member ![]() ![]() Group: Members Posts: 273 Joined: 14-June 03 From: Monroeville, PA Member No.: 821 ![]() |
Borrowed a compression tester to see my mechanics results are correct or is he just trying to sell me an engine rebuild. Range went from 100 psi on #1 to 150psi on #4. # 2 and 3 were at 120. Never done this before, but I have removed all spark plugs and the coil wire from the coil to the distrib. Do I need to disable the fuel pump? What's the easiest thing to do, pull a relay or a fuse? Anything else I need to watch out for or do? Thanks in advance for the advice and help!
john rogers |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 ![]() |
There are several additoinal things to do. Warm up the engine first to operating temp so the rings and valves will be seated better. Pull the relay for the fuel pump so it will not run. Pull the air cleaner off and then tie the throttle body full open. Put a note on the dash in front of the tach so you will remember to untie the throttle body.
Lo-Fi Version | Time is now: 4th July 2025 - 09:17 PM |
