Fuel Line / EFI Installation, Alum / Braided Lines & Holley EFI on V8 |
jridder |
Feb 5 2004, 07:33 PM
Member Group: Members Posts: 136 Joined: 5-May 03 From: Sunnyvale, CA Member No.: 656 |
Here's some pictures of my installation of aluminum and braided fuel lines and a Holley Commander 950 TBI system on my V8.
First pic shows the 3/8" aluminum fuel lines in the area under the gas tank. Attached image(s) |
jridder |
Feb 5 2004, 08:04 PM
The left side of the engine compartment. Not much to see here. The water temp sensor is on the top right of the pic. The water going to the radiator used to exit on this side but I moved it to the other side to make the hose routing under the car work better.
You can also see the single torsion spring on the engine compartment lid. With the rain tray removed, a single spring is just about right for raising the lid. With two springs you have to hold the lid or it will slam violently into the targa bar trim. Attached image(s) |
Lo-Fi Version | Time is now: 2nd June 2024 - 02:57 PM |
