> Throttle position switch (TPS) repair, Contact surfaces are worn
Cevan
post May 11 2009, 11:47 AM
I've completed my 1.8 to 2.0 motor swap and have my car running really good, except the TPS is worn right around the partially open throttle position.
I've cleaned the surface and the contacts with 2000 grit sandpaper and then used Deoxit electrial contact cleaner. This helped as it only hesitates/bucks at the barely open throttle position and cleared up the issue at positions further along the path of travel. I imagine that it's worn right at the spot where you're most often running at.
I searched but couldn't find any threads on repairing this. What I want to do is move the circuit board to the right or left, so that the contacts run on a fresh part of the board. Any ideas on how to separate the circuit board from the metal body and how best to reattach it? It looks like it may be soldered at the bottom right corner.
JeffBowlsby
post Jun 23 2009, 01:51 PM
Thanks for making these Dave...we have been in need for too long.
Can you tell us why you did not select a screw and used a rivet?
davesprinkle
post Jun 23 2009, 02:19 PM
QUOTE(Jeff Bowlsby @ Jun 23 2009, 12:51 PM) *
Jeff,
I considered a screw. You could make it work, but here's why I didn't:
1. OE hole is roughly 1.5mm diameter. Tiny.
2. You could thread the baseplate, but a few problems are: 1.5mm base thickness means very few threads, most people don't have tiny taps, and tapping is very error-prone (some people would be successful, but probably 50% wouldn't).
3. You could use a screw/nut combination, but only at the risk of the tiny fastener coming loose. Locknuts aren't available in smaller than 3mm, so you'd be drilling out the hole anyway.
4. Those tiny fasteners are fiddly and disproportionately expensive.
So much for the cons, here are the pros:
1. A rivet will hold tight.
2. A rivet won't fail due to engine heat.
3. A rivet is cheap.
4. A rivet is so easy to install, a caveman could do it.
I wish I could have gotten a pop-rivet that matched the factory diameter, but no luck. I don't like having to drill out the baseplate, but I think on balance it's the best choice -- functionality at the expense of a slight deviation from the factory design. I know the tradeoff won't work for Pat Garvey (bless his concours heart), but the rest of us will probably agree it's worthwhile.
warrenoliver
post Jun 24 2009, 05:02 PM
QUOTE(davesprinkle @ Jun 23 2009, 03:19 PM) *
Jeff,
How about JB Weld? Wouldn't that work even better? (IMG:style_emoticons/default/poke.gif)
(IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif)
Nice job on the board, I'll be interested in the test results.
Warrenoliver
Cevan   Throttle position switch (TPS) repair   May 11 2009, 11:47 AM
McMark   Using careful pressure, you can slightly bend the ...   May 11 2009, 11:50 AM
Gint   Using careful pressure, you can slightly bend the ...   Jun 15 2009, 08:54 PM
Cevan   Thanks McMark. I did as you suggested and gently ...   May 12 2009, 05:39 AM
Derek Seymour   I think this may have already been mentioned, but ...   Jun 15 2009, 02:20 PM
rjames   I think this may have already been mentioned, but...   Jun 15 2009, 02:23 PM
Cevan   I fixed mine in about 10 minutes, from start to fi...   Jun 15 2009, 02:31 PM
Derek Seymour   It may kill it for some but for others I suspect t...   Jun 15 2009, 03:29 PM
r_towle   Isnt that gold? Could gold leafbe applied tofix th...   Jun 15 2009, 05:11 PM
worn   Isnt that gold? Could gold leafbe applied tofix t...   Sep 27 2018, 01:28 AM
davesprinkle   I have a board house manufacturing these circuit b...   Jun 15 2009, 07:14 PM
Derek Seymour   I have a board house manufacturing these circuit ...   Jun 15 2009, 08:09 PM
mikeg4   [quote name='davesprinkle' date='Jun 1...   Feb 16 2010, 08:31 PM
davesprinkle   I have a board house manufacturing these circuit...   Feb 16 2010, 09:02 PM
Pat Garvey   The the original on my 72 was never as worn as you...   Jun 15 2009, 08:37 PM
davesprinkle   Circuit boards arrived. Here's a pic. Testin...   Jun 22 2009, 08:49 AM
davesprinkle   More pics of initial board installation in this th...   Jun 22 2009, 03:37 PM
johnwmrvw   Hello, I'm interested in your circuit board. I...   Feb 10 2010, 09:44 PM
McMark   <_< Posting pictures here is apparently dif...   Jun 23 2009, 01:00 AM
davesprinkle   <_< Posting pictures here is apparently di...   Jun 23 2009, 09:50 AM
kwales   Yeah, that's a really good picture on the othe...   Jun 23 2009, 09:46 AM
davesprinkle   A business card makes a good ramp for getting the ...   Jun 23 2009, 09:51 AM
davesprinkle   Here's a pic of the board with the business ca...   Jun 23 2009, 09:51 AM
davesprinkle   Rivet installed. I would urge you to fend off the...   Jun 23 2009, 09:54 AM
davesprinkle   Here is a pic with the connector reinstalled onto ...   Jun 23 2009, 09:56 AM
McMark   :rotfl: Yeah, about 1% of the same content and s...   Jun 23 2009, 11:08 AM
Jeff Bowlsby   Thanks for making these Dave...we have been in nee...   Jun 23 2009, 01:51 PM
davesprinkle   Thanks for making these Dave...we have been in ne...   Jun 23 2009, 02:19 PM
Jeff Bowlsby   That seems well thought out Dave. While a screw c...   Jun 23 2009, 02:36 PM
davesprinkle   That seems well thought out Dave. While a screw ...   Jun 23 2009, 02:39 PM
Jeff Bowlsby   Thats great! I would be happy to be a 2.0L mu...   Jun 23 2009, 03:17 PM
warrenoliver   Thanks for making these Dave...we have been in n...   Jun 24 2009, 05:02 PM
davesprinkle   How about JB Weld? Wouldn't that work even...   Jun 25 2009, 12:53 AM
warrenoliver   How about JB Weld? Wouldn't that work eve...   Jun 25 2009, 11:25 AM
kwales   Gee Jeff, The answer to that is obvious.... Con...   Jun 23 2009, 01:59 PM
RoadGlue   Subscribed to this thread. This looks awesome. Nic...   Jun 23 2009, 03:12 PM
Tom   Dave, Outstanding job. I remember doing some sma...   Jun 23 2009, 03:49 PM
Cevan   Even though I fixed mine (at least temporarily), I...   Jun 23 2009, 04:30 PM
davesprinkle   Question: Is the conductive material on the board...   Jun 23 2009, 06:45 PM
davesprinkle   Everyone, I still haven't found a suitable tes...   Jun 29 2009, 10:23 PM
sixnotfour   dave a ,local shop told me AA has the boards too ?...   Jun 29 2009, 11:27 PM
davesprinkle   dave a ,local shop told me AA has the boards too ...   Jun 29 2009, 11:44 PM
davesprinkle   I've got a late 1.7liter TPS here. It appears...   Jun 30 2009, 02:26 PM
Derek Seymour   :bump:   Jul 1 2009, 11:46 AM
rjames   I'm wishing my Seattle teener was in Portland ...   Jul 1 2009, 01:36 PM
davesprinkle   Jeff Bowlsby installed the board on his 2.0liter. ...   Jul 6 2009, 09:29 PM
sixnotfour   Thanks for helping Mark . Jeff   Jul 6 2009, 09:45 PM
Mikey914   I have a 76 2.0 that is local. Unfortunately, I st...   Jul 6 2009, 09:55 PM
RoadGlue   Bump! I REALLY want two of these ASAP. :) Any ...   Jul 19 2009, 12:08 AM
davesprinkle   OK everybody, sorry for the delay. I've compl...   Aug 24 2009, 10:53 PM
RoadGlue   Hooray! How do we order?   Aug 24 2009, 11:49 PM
davesprinkle   Hooray! How do we order? You can either sen...   Aug 25 2009, 08:42 AM
RoadGlue   I ordered two! Who's next? *bump*   Aug 25 2009, 03:35 PM
davesprinkle   I ordered two! Who's next? *bump* Rand...   Aug 25 2009, 06:37 PM
davesprinkle   I just received the boards for the late 1.7liter c...   Jan 28 2010, 09:15 PM
Rod   I just received the boards for the late 1.7liter ...   Jan 29 2010, 12:29 PM
davesprinkle   I just received the boards for the late 1.7liter...   Jan 29 2010, 07:12 PM
pbanders   Dave, this is all great stuff! Awesome enginee...   Jan 29 2010, 10:44 AM
McMark   Dave, could you add something in the Member Vendor...   Feb 3 2010, 11:29 PM
ericread   I purchased and installed the new TPS, but I'l...   Feb 17 2010, 05:19 PM
davesprinkle   I purchased and installed the new TPS, but I...   Feb 17 2010, 10:52 PM
ericread   Eric, the switch is designed with hysteresis (ba...   Feb 18 2010, 08:41 AM
hushpuppy   dave, do you still have any of the boards left 7...   Sep 21 2018, 06:57 PM
jagalyn   dave, do you still have any of the boards left ...   Sep 26 2018, 08:17 PM
ChrisFoley   dave, do you still have any of the boards left...   Sep 27 2018, 06:37 AM
Mikey914   [quote name='jagalyn' post='2652419' date='Sep 26...   Sep 29 2018, 10:31 PM
davesprinkle   dave, do you still have any of the boards left ...   Sep 30 2018, 01:11 AM
Tbrown4x4   914Rubber has the boards in stock. Oops. I didn...   Sep 27 2018, 02:44 AM
jagalyn   https://shop.914rubber.com/Porsche-914-Thro...m?ca...   Sep 27 2018, 07:14 AM
- Lo-Fi Version Time is now: 9th June 2026 - 10:34 PM
