kpfoten |
Member ![]() ![]() Group: Members Posts: 220 Joined: 15-April 08 From: Escanaba, MI Member No.: 8,927 Region Association: None ![]() |
Here's what happened: I pulled the connector to the circuit board in my '73 1.7L, then pulled the fuse and relays to check continuity. When I put everything back together, I connected the battery and the thing turns over! The key is not in the ignition. What did I do? Help! |
kpfoten |
Well, I've pulled all relays and fuse on the circuit board and it is still doing it. When I pulled the main harness plug off, a small piece of plastic cracked on the harness plug (T14 connector?) near the #13 pin area. Could something be "jumping" between the two terminals (last two on the right)? |
Lo-Fi Version | Time is now: 1st August 2025 - 06:23 AM |
