Help me diagnose/fix my relay board! |
kpfoten |
Jun 25 2009, 03:47 PM
Member Group: Members Posts: 220 Joined: 15-April 08 From: Escanaba, MI Member No.: 8,927 Region Association: None |
My '73 1.7 is getting the FI system re-installed after the PO put carbs in.
I'm not getting power to my fuel pump--I've tested continuity and think my problem lies in the relay board. The left post for the 25A fuse should receive 12V and I'm getting nothing. The post looks a little melted like something happened to it at one point. The rivet from underneath (red, 2nd picture) is continuous, but this should extend onto the tract (not sure the correct terminology), right? There seems to be a break between the rivet and the tract (green). Sorry about the lack of focus... If so, how do I make a quick fix? Thanks! Attached image(s) |
76-914 |
Jun 25 2009, 11:36 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,507 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
if there is no continuity between the rivet and the surface you can clean the area and solder the rivet to the surface.
Lo-Fi Version | Time is now: 31st May 2024 - 05:58 PM |
