Help! I'm Stymied!, Only firing on #3 and # 4 |
DipShit |
Jun 12 2009, 10:19 AM
Member Group: Members Posts: 199 Joined: 26-May 04 From: Cheyenne, WY Member No.: 2,107 |
1.7 D-Jet
Engine was running just great until about two weeks ago, sigh. Now only fires on # 3 and # 4. I have cleaned every connection including all grounds. And I mean cleaned them good! The elecrical appears to be just fine. I get a good noid light at both # 1 and # 2. The injectors have tested just fine as well (I'm getting about 7cc in 15 seconds). I have 40lbs of pressure the 1,2 rail. The spark plugs are getting juice and fire. I have installed new points, cleaned the triggers (which shouldn't have mattered because of the sequence) and set the dwell. I'm a tad under at 44 degrees, but again shouldn't keep # 1 and # 2 from firing. The timing has to be close as it runs really smooth for just two cylinders. If I pull the power to injector 3 or 4, I get a real good drop and she will die. If I pull 1 or 2 - no change. If I add propane to the intake, I get a good response in higher rpm. I had originally traced to the Temp II sensor and it failed, so I replaced it. A new one seemed to be the fix, but only for a moment. I have good fuel, spark and air - (IMG:style_emoticons/default/WTF.gif) I'm STYMIED (or just a REAL DIPSHIT) |
DipShit |
Jun 26 2009, 09:24 AM
Here is the latest that I have done and I am STILL just running on # 3 and # 4:
Cleaned and Checked all Grounds Replaced Temp Sensor II Swapped out ECU Swapped Wiring Harnmess Cleaned points, contacts and set Dwell Adjusted the timing Adjusted the valves - now 110, 110, 100, 95 was 125 120 100 80 Swapped Dizzy Cap Swapped Plug wires to test Swapped Coil Checked Fuel Pressure - 30 psi Checked Flow/Spray of Injectors 7cc in 15 seconds, nice spray pattern Still no joy with 1&2 and only running on # 3 and # 4 (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/WTF.gif) |
Lo-Fi Version | Time is now: 8th June 2024 - 10:30 AM |
