On a 5 lug conversion, are the rear studs longer than the fronts? |
turnaround89 |
Jun 29 2009, 12:04 AM
Senior Member Group: Members Posts: 671 Joined: 17-May 08 From: Rockford, Illinois Member No.: 9,067 Region Association: Upper MidWest |
Is the most common length for a wheel stud for fuchs rims 45mm? Are the rear lugs supposed to be longer at 52mm, or are they also 45mm?
Also, why are wheel studs 7 dollars a stud? Have to buy 20 studs, 140 for studs is a little crazy |
turnaround89 |
Jun 29 2009, 07:04 AM
Sir Andy, do you use the open ended lug nut for the 100mm stud? I have a set of, i guess, closed end lug nuts for the fuchs already and plan on using those. I really don't want to spend 200 on studs, but if thats what has to happen then i guess ill have to deal with it, kind of shocking when a stud for my pontiac is 1.49
SirAndy |
Jun 29 2009, 09:36 AM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Sir Andy, do you use the open ended lug nut for the 100mm stud? Yes ... Crappy pic, but you can see them: Attached image(s) |
Lo-Fi Version | Time is now: 1st June 2024 - 10:53 PM |
