| FourBlades |
Jun 29 2009, 06:00 PM
From Wreck to Rockin ![]() ![]() ![]() ![]() Group: Members Posts: 2,056 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States
I have seen different things discussed, like welding up some
pieces custom, using a plumber's nightmare of 2 different barb fittings and a connector, the mythical fuel filter with 9mm inlet and 7mm outlet. What is the best way to deal with this? Thanks, John |
| dr914@autoatlanta.com |
Jun 29 2009, 06:03 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,242 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
I have seen different things discussed, like welding up some pieces custom, using a plumber's nightmare of 2 different barb fittings and a connector, the mythical fuel filter with 9mm inlet and 7mm outlet. What is the best way to deal with this? Thanks, John \ the seven/nine step hose |
FourBlades What is the best way to connect the 9mm to 7mm gas lines? Jun 29 2009, 06:00 PM
tradisrad yep- a special hose Jun 29 2009, 06:08 PM
Cap'n Krusty While the answer to life, the universe, and all th... Jun 29 2009, 06:11 PM
FourBlades OK, so what is the part number, and is it still av... Jun 29 2009, 06:16 PM
championgt1 I just bought one of these. it worked great. The c... Jun 29 2009, 11:47 PM
dangrouche i added one of these tubing adaptors and it makes ... Jun 30 2009, 06:40 PM
Cap'n Krusty
i added one of these tubing adaptors and it makes... Jun 30 2009, 07:06 PM
dangrouche
i added one of these tubing adaptors and it make... Jul 1 2009, 12:57 AM
FourBlades OK, so I am running carbs and want to locate my fu... Jul 2 2009, 07:16 PM
roadster fan
I have a buncha 5/16 and 3/8 barbed fittings I... Jul 3 2009, 02:30 PM
neil30076
I have a buncha 5/16 and 3/8 barbed fittings ... Jul 3 2009, 06:47 PM
Racer Chris
I figure I need one steppen hosen from the tank t... Jul 3 2009, 03:22 PM
FourBlades :bump: Jul 3 2009, 02:06 PM
davesprinkle Pipe threads have no place in a fuel system.
The... Jul 3 2009, 07:20 PM
Porsche Rescue I also recently faced this issue. After being sham... Jul 3 2009, 07:28 PM
FourBlades Thanks for all the info.
How long is the tapered ... Jul 3 2009, 07:48 PM
Porsche Rescue Not sure I understand what you mean by "front... Jul 3 2009, 08:13 PM![]() ![]() |
Lo-Fi Version | Time is now: 7th September 2026 - 02:02 AM |
