| FourBlades |
Jun 29 2009, 06:00 PM
From Wreck to Rockin ![]() ![]() ![]() ![]() Group: Members Posts: 2,056 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States
I have seen different things discussed, like welding up some
pieces custom, using a plumber's nightmare of 2 different barb fittings and a connector, the mythical fuel filter with 9mm inlet and 7mm outlet. What is the best way to deal with this? Thanks, John |
| dangrouche |
Jun 30 2009, 06:40 PM
dangrouche ![]() ![]() ![]() Group: Members Posts: 550 Joined: 1-May 04 From: San Francisco Bay Area Member No.: 2,012 Region Association: None |
i added one of these tubing adaptors and it makes you never have to worry about a step down hose that is expensive and hard to find. thanks Chris at CFR!
FourBlades What is the best way to connect the 9mm to 7mm gas lines? Jun 29 2009, 06:00 PM
dr914@autoatlanta.com
I have seen different things discussed, like weld... Jun 29 2009, 06:03 PM
tradisrad yep- a special hose Jun 29 2009, 06:08 PM
Cap'n Krusty While the answer to life, the universe, and all th... Jun 29 2009, 06:11 PM
FourBlades OK, so what is the part number, and is it still av... Jun 29 2009, 06:16 PM
championgt1 I just bought one of these. it worked great. The c... Jun 29 2009, 11:47 PM
Cap'n Krusty
i added one of these tubing adaptors and it makes... Jun 30 2009, 07:06 PM
dangrouche
i added one of these tubing adaptors and it make... Jul 1 2009, 12:57 AM
FourBlades OK, so I am running carbs and want to locate my fu... Jul 2 2009, 07:16 PM
roadster fan
I have a buncha 5/16 and 3/8 barbed fittings I... Jul 3 2009, 02:30 PM
neil30076
I have a buncha 5/16 and 3/8 barbed fittings ... Jul 3 2009, 06:47 PM
Racer Chris
I figure I need one steppen hosen from the tank t... Jul 3 2009, 03:22 PM
FourBlades :bump: Jul 3 2009, 02:06 PM
davesprinkle Pipe threads have no place in a fuel system.
The... Jul 3 2009, 07:20 PM
Porsche Rescue I also recently faced this issue. After being sham... Jul 3 2009, 07:28 PM
FourBlades Thanks for all the info.
How long is the tapered ... Jul 3 2009, 07:48 PM
Porsche Rescue Not sure I understand what you mean by "front... Jul 3 2009, 08:13 PM![]() ![]() |
Lo-Fi Version | Time is now: 7th September 2026 - 02:01 AM |
