> What is the best way to connect the 9mm to 7mm gas lines?, Now with additional dumb questions at the end...
FourBlades
post Jun 29 2009, 06:00 PM
From Wreck to Rockin
I have seen different things discussed, like welding up some
pieces custom, using a plumber's nightmare of 2 different
barb fittings and a connector, the mythical fuel filter with 9mm
inlet and 7mm outlet. What is the best way to deal with this?
Thanks,
John
dangrouche
post Jun 30 2009, 06:40 PM
dangrouche
i added one of these tubing adaptors and it makes you never have to worry about a step down hose that is expensive and hard to find. thanks Chris at CFR!
Cap'n Krusty
post Jun 30 2009, 07:06 PM
Cap'n Krusty
QUOTE(dangrouche @ Jun 30 2009, 05:40 PM) *
So, how much was the tube? I reckon the only place to get that thing is from CFR, while the $20-25 hose is available at any Porsche dealer in the world, although they'll have to order it. And you won't need 2 pieces of hose and 4 hose clamps, either.
The Cap'n
dangrouche
post Jul 1 2009, 12:57 AM
dangrouche
QUOTE(Cap'n Krusty @ Jun 30 2009, 06:06 PM) *
The Cap'n
$10.95 delivered price, yes, have to use two bits of hose and four clamps to join it all together.
FourBlades   What is the best way to connect the 9mm to 7mm gas lines?   Jun 29 2009, 06:00 PM
dr914@autoatlanta.com   I have seen different things discussed, like weld...   Jun 29 2009, 06:03 PM
tradisrad   yep- a special hose   Jun 29 2009, 06:08 PM
Cap'n Krusty   While the answer to life, the universe, and all th...   Jun 29 2009, 06:11 PM
FourBlades   OK, so what is the part number, and is it still av...   Jun 29 2009, 06:16 PM
championgt1   I just bought one of these. it worked great. The c...   Jun 29 2009, 11:47 PM
dangrouche   i added one of these tubing adaptors and it makes ...   Jun 30 2009, 06:40 PM
Cap'n Krusty   i added one of these tubing adaptors and it makes...   Jun 30 2009, 07:06 PM
dangrouche   i added one of these tubing adaptors and it make...   Jul 1 2009, 12:57 AM
FourBlades   OK, so I am running carbs and want to locate my fu...   Jul 2 2009, 07:16 PM
roadster fan   I have a buncha 5/16 and 3/8 barbed fittings I...   Jul 3 2009, 02:30 PM
neil30076   I have a buncha 5/16 and 3/8 barbed fittings ...   Jul 3 2009, 06:47 PM
Racer Chris   I figure I need one steppen hosen from the tank t...   Jul 3 2009, 03:22 PM
FourBlades   :bump:   Jul 3 2009, 02:06 PM
davesprinkle   Pipe threads have no place in a fuel system. The...   Jul 3 2009, 07:20 PM
Porsche Rescue   I also recently faced this issue. After being sham...   Jul 3 2009, 07:28 PM
FourBlades   Thanks for all the info. How long is the tapered ...   Jul 3 2009, 07:48 PM
Porsche Rescue   Not sure I understand what you mean by "front...   Jul 3 2009, 08:13 PM
- Lo-Fi Version Time is now: 7th September 2026 - 02:02 AM
