> Shifting Issues, Does this bushing look OK?
ellisor3
post Jul 4 2009, 11:26 AM
HPWhore
I have been trying to figure out why I can not shift into any gear. I checked to see if the Clutch Tube was broken and it seems fine. I also looked at the bushing at the fire wall and they seem fine. My next check was at the shift rod head. It seems that the bushing here has a lot of play, is this normal??
Here are a few pics, thanks in advance for the help.
naro914
post Jul 4 2009, 05:52 PM
Losing my mind...
if you hold it there will it stay in gear?
Check the bolt below the shifter that connects the shifter to the shift rod. If it comes loose, it will allow you to move the shifter without it moving the shift rod completly.
The suggestion above is what you need to do, have someone shift it when its off, and watch it go into and out of gears. See if anything is binding or hitting.
I had a problem once that had the coupler hitting the bushing that McMark pointed to (the bushing is there, right??). no clue why it started to happen, just out of the blue. It hit the bushing which kept it from moving all the way into gear.
ellisor3
post Jul 5 2009, 11:30 AM
HPWhore
QUOTE(naro914 @ Jul 4 2009, 07:52 PM) *
That was a good catch, the bushing slipped out of the hole. I could not tell until I completely backed the cover off. It snapped back in and appears tight now. Thanks for the extra set of eyes. (IMG:style_emoticons/default/aktion035.gif)
- Lo-Fi Version Time is now: 12th July 2025 - 10:35 AM
