> What did I do? Car wants to start when connecting battery!
kpfoten
post Jun 24 2009, 06:52 PM
Here's what happened:
I pulled the connector to the circuit board in my '73 1.7L, then pulled the fuse and relays to check continuity. When I put everything back together, I connected the battery and the thing turns over! The key is not in the ignition. What did I do? Help!
kpfoten
post Jul 5 2009, 06:22 PM
It didn't crank (was normal) until I unplugged the 14 pin from the relay board and went to plug it back in. I'm investigating a cracked connector--hopefully something is associated with it... (it cracked as I was removing it (and I thought I was gentle...)).
Will work on it tonight...
kpfoten   What did I do? Car wants to start when connecting battery!   Jun 24 2009, 06:52 PM
cwpeden   Sounds like you put one of the relays in wrong.   Jun 24 2009, 07:31 PM
RobW   Clearly you are omitting a portion or two of the s...   Jun 24 2009, 07:43 PM
tat2dphreak   Clearly you are omitting a portion or two of the ...   Jun 24 2009, 08:33 PM
kpfoten   I was wearing dark britches.... :) I thought the ...   Jun 24 2009, 08:15 PM
McMark   Check that the connector on the relay board is in ...   Jun 24 2009, 08:27 PM
kpfoten   Yeah, that's what I thought initially--althoug...   Jun 24 2009, 08:35 PM
kpfoten   Well, I've pulled all relays and fuse on the c...   Jun 24 2009, 08:34 PM
McMark   You didn't do anything with the wiring at the ...   Jun 24 2009, 08:45 PM
McMark   B)   Jun 24 2009, 08:48 PM
kpfoten   Thanks for the diagram--could I have reversed the ...   Jun 24 2009, 09:00 PM
kpfoten   BUMP Made sure things are hooked up correctly on ...   Jun 26 2009, 01:43 PM
tat2dphreak   the ones on the solenoid are the only ones I can ...   Jun 26 2009, 01:49 PM
kpfoten   Doesn't seem to be the ignition switch (unplug...   Jun 26 2009, 02:17 PM
tat2dphreak   I dunno if you can buy them separate or not. you c...   Jun 26 2009, 02:50 PM
RJMII   or you could bench test the starter... make sure t...   Jun 26 2009, 02:54 PM
Cap'n Krusty   How could anyone possibly think the relays or fuse...   Jun 26 2009, 04:22 PM
neil30076   How could anyone possibly think the relays or fus...   Jun 26 2009, 05:34 PM
McMark   :agree: Pull the yellow wire and see if the proble...   Jun 26 2009, 08:47 PM
kpfoten   Yeah, I was thinking of checking the yellow wire. ...   Jun 26 2009, 09:25 PM
kpfoten   Yellow wire pulled from solenoid--does not start o...   Jul 1 2009, 09:05 AM
underthetire   I had a similar issue when my cold start injector ...   Jul 1 2009, 10:07 AM
McMark   Pull the rearward connector from the relay board a...   Jul 1 2009, 10:08 AM
kpfoten   Key switch disconnected -- Engine Cranks when cabl...   Jul 4 2009, 02:57 PM
McMark   I doubt it will help. I'd be looking more at ...   Jul 4 2009, 05:06 PM
Dave_Darling   The problem started when you unplugged and plugged...   Jul 4 2009, 09:24 PM
charliew   I sounds to me like you were trying to fix another...   Jul 5 2009, 05:42 PM
kpfoten   It didn't crank (was normal) until I unplugged...   Jul 5 2009, 06:22 PM
kpfoten   How many of you were banking on the fact that I...   Jul 5 2009, 07:17 PM
charliew   The connector probably cracked when you forced it ...   Jul 6 2009, 10:07 AM
kpfoten   Yeah, the connector cracked as I was pulling it up...   Jul 6 2009, 12:24 PM
McMark   :trophy:   Jul 6 2009, 01:51 PM
- Lo-Fi Version Time is now: 1st August 2025 - 06:17 AM
