> fried wire - ignition on
jimkelly
post Jul 6 2009, 04:40 PM
Delaware USA
why did my wire from my coil to my points/condensor fry - up in smoke : (
jt914-6
post Jul 7 2009, 04:05 PM
The condenser wire and the tach wire (blackW/purple stripe) go to the negative side of the coil.
Take a test light and see if the "black" wire is hot with the key on. If so, that wire goes to the positive side of the coil.
You may have to peel back some of the sheath to determine which wire is the tach wire (black/purple).
jimkelly   fried wire - ignition on   Jul 6 2009, 04:40 PM
messix   the rear relay board harness plugged in one set on...   Jul 6 2009, 04:47 PM
Project 6   Something grounded out. You're gonna need a F...   Jul 6 2009, 05:03 PM
jt914-6   The condensor wire should be connected to the nega...   Jul 6 2009, 05:17 PM
914Sixer   In George's Tech Tip book page 84, 621: Never...   Jul 7 2009, 12:38 PM
Cap'n Krusty   In Georges Tech Tip book page 84, 621: Never lea...   Jul 7 2009, 02:39 PM
jimkelly   dang : ( appreciate the explanation though : ) j...   Jul 7 2009, 01:33 PM
jimkelly   i could have sworn that i did not move this wire f...   Jul 7 2009, 03:16 PM
Spoke   i just ordered some crimps and a good crimp tool ...   Jul 7 2009, 03:57 PM
jt914-6   The condenser wire and the tach wire (blackW/purpl...   Jul 7 2009, 04:05 PM
Cap'n Krusty   Soldering is NOT recommended for automotive wiring...   Jul 7 2009, 04:05 PM
underthetire   Soldering is NOT recommended for automotive wirin...   Jul 7 2009, 04:19 PM
Jeff Bowlsby   Soldering is NOT recommended for automotive wirin...   Jul 7 2009, 06:58 PM
jimkelly   i am going this route. http://www.914world.com/bb...   Jul 7 2009, 04:15 PM
charliew   Cap'n you will have to give me a real good exp...   Jul 7 2009, 04:34 PM
underthetire   Cap'n you will have to give me a real good ex...   Jul 7 2009, 04:52 PM
Cap'n Krusty   Might I add the FAA forbids soldering wires and co...   Jul 7 2009, 05:48 PM
charliew   I think I remember aircraft uses 400ac voltage and...   Jul 7 2009, 06:57 PM
Spoke   Well I certainly opened a can of worms by suggesti...   Jul 8 2009, 12:16 PM
jimkelly   i think different plans of attack work best in cer...   Jul 8 2009, 12:36 PM
ghuff   This comes up on every auto forum. I do soldering...   Jul 8 2009, 04:58 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 02:30 PM
