> fried wire - ignition on
jimkelly
post Jul 6 2009, 04:40 PM
Delaware USA
why did my wire from my coil to my points/condensor fry - up in smoke : (
charliew
post Jul 7 2009, 04:34 PM
Cap'n you will have to give me a real good explanation of how any compression fitting on a wire is better than a soldered connection. I have been using soldered connections on everything I connect electrically for 40 years and have had much better reliability with solder than a crimped connection. I know for a fact that corrosion happens inside a crimped connection. Also the connector is much stronger when the wire is pulled on when the connector is disconnected. I remember the deal about acid core solder but that is known to damage any circuit and it's components but we are of course talking about rosen core solder. All circuit boards have their components soldered on.
I am very interested in your facts on your crimp versus solder connections or a link to your information. I will also search the web for this info as I am not aware of any new info about what you are stating. But that really would not surprise me as I do live in my on little world.
http://ocw.weber.edu/automotive-technology...epair/soldering
This only explains to correct way to solder a terminal on.
OOokkay it seems the change from the good ole stuff to leadfree stuff is the deal.
http://www.ko-ki.co.jp/technical/05.html
I'll just stick with what I know works thank you. The only problem I forsee is the real solder availability.
jimkelly   fried wire - ignition on   Jul 6 2009, 04:40 PM
messix   the rear relay board harness plugged in one set on...   Jul 6 2009, 04:47 PM
Project 6   Something grounded out. You're gonna need a F...   Jul 6 2009, 05:03 PM
jt914-6   The condensor wire should be connected to the nega...   Jul 6 2009, 05:17 PM
914Sixer   In George's Tech Tip book page 84, 621: Never...   Jul 7 2009, 12:38 PM
Cap'n Krusty   In Georges Tech Tip book page 84, 621: Never lea...   Jul 7 2009, 02:39 PM
jimkelly   dang : ( appreciate the explanation though : ) j...   Jul 7 2009, 01:33 PM
jimkelly   i could have sworn that i did not move this wire f...   Jul 7 2009, 03:16 PM
Spoke   i just ordered some crimps and a good crimp tool ...   Jul 7 2009, 03:57 PM
jt914-6   The condenser wire and the tach wire (blackW/purpl...   Jul 7 2009, 04:05 PM
Cap'n Krusty   Soldering is NOT recommended for automotive wiring...   Jul 7 2009, 04:05 PM
underthetire   Soldering is NOT recommended for automotive wirin...   Jul 7 2009, 04:19 PM
Jeff Bowlsby   Soldering is NOT recommended for automotive wirin...   Jul 7 2009, 06:58 PM
jimkelly   i am going this route. http://www.914world.com/bb...   Jul 7 2009, 04:15 PM
charliew   Cap'n you will have to give me a real good exp...   Jul 7 2009, 04:34 PM
underthetire   Cap'n you will have to give me a real good ex...   Jul 7 2009, 04:52 PM
Cap'n Krusty   Might I add the FAA forbids soldering wires and co...   Jul 7 2009, 05:48 PM
charliew   I think I remember aircraft uses 400ac voltage and...   Jul 7 2009, 06:57 PM
Spoke   Well I certainly opened a can of worms by suggesti...   Jul 8 2009, 12:16 PM
jimkelly   i think different plans of attack work best in cer...   Jul 8 2009, 12:36 PM
ghuff   This comes up on every auto forum. I do soldering...   Jul 8 2009, 04:58 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 12:33 PM
