| jimkelly |
Jul 6 2009, 04:40 PM
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
why did my wire from my coil to my points/condensor fry - up in smoke : (
| charliew |
Jul 7 2009, 06:57 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 |
I think I remember aircraft uses 400ac voltage and aircraft wiring usually vibrates alot. Also it's pretty easy to screw up a solder joint and a crimp is a lot faster and maybe harder to screw up. The thing it don't like to deal with on crimps is they get corroded and loose from age. The heating and cooling makes the metal loose.
For the guys that like to read this seems like my kinda place. Check out post 25. http://www.jalopyjournal.com/forum/showthr...lder&page=2 Leadfree problems in the repair of electronics: Post 39 |
jimkelly fried wire - ignition on Jul 6 2009, 04:40 PM
messix the rear relay board harness plugged in one set on... Jul 6 2009, 04:47 PM
Project 6 Something grounded out. You're gonna need a F... Jul 6 2009, 05:03 PM
jt914-6 The condensor wire should be connected to the nega... Jul 6 2009, 05:17 PM
914Sixer In George's Tech Tip book page 84, 621:
Never... Jul 7 2009, 12:38 PM
Cap'n Krusty
In Georges Tech Tip book page 84, 621:
Never lea... Jul 7 2009, 02:39 PM
jimkelly dang : (
appreciate the explanation though : )
j... Jul 7 2009, 01:33 PM
jimkelly i could have sworn that i did not move this wire f... Jul 7 2009, 03:16 PM
Spoke
i just ordered some crimps and a good crimp tool ... Jul 7 2009, 03:57 PM
jt914-6 The condenser wire and the tach wire (blackW/purpl... Jul 7 2009, 04:05 PM
Cap'n Krusty Soldering is NOT recommended for automotive wiring... Jul 7 2009, 04:05 PM
underthetire
Soldering is NOT recommended for automotive wirin... Jul 7 2009, 04:19 PM
Jeff Bowlsby
Soldering is NOT recommended for automotive wirin... Jul 7 2009, 06:58 PM
jimkelly i am going this route.
http://www.914world.com/bb... Jul 7 2009, 04:15 PM
charliew Cap'n you will have to give me a real good exp... Jul 7 2009, 04:34 PM
underthetire
Cap'n you will have to give me a real good ex... Jul 7 2009, 04:52 PM
Cap'n Krusty Might I add the FAA forbids soldering wires and co... Jul 7 2009, 05:48 PM
Spoke Well I certainly opened a can of worms by suggesti... Jul 8 2009, 12:16 PM
jimkelly i think different plans of attack work best in cer... Jul 8 2009, 12:36 PM
ghuff This comes up on every auto forum.
I do soldering... Jul 8 2009, 04:58 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 02:28 PM |
