> Mocal vs Tilton oils cooler pumps, One better than the other?
pcar916
post Jul 6 2009, 08:21 AM
Is that a Lola?
I'm adding a cooler and pump to my transmission. These two pumps are similar in specification and both companies have been around a long time.
Tilton: http://www.summitracing.com/parts/TIL-40-524/
Mocal: http://www.racerpartswholesale.com/product...ial_Cooler_Pump
I know several of you run Jabsco Water Puppy pumps, but I see no advantage to it over the Mocal or Tilton.
Anyone out there with experience as to whether one is more reliable than the other?
pcar916
post Jul 6 2009, 09:21 PM
Is that a Lola?
You could do it if you ignored squirters on the gears, and perhaps used the drain and fill plugs for in and out of your fluid after the fluid was drained.
But with some finesse, you can take the transaxle out without taking the motor out. Then you can install brass/bronze bosses for your cooler system elsewhere on the case.
If you decide to install squirters, don't make the mistake of pointing the oil flow into the mesh areas of the gears and R&P. That makes for huge forces pushing them apart as they try to squeeze the oil out from the mesh.
stownsen914
post Jul 7 2009, 08:00 AM
QUOTE(pcar916 @ Jul 6 2009, 11:21 PM) *
I have heard this elsewhere, and am interested knowing why it matters. If you look at a the oil level in a stock 901, the gears mesh very close to that point. It seems like the oil would be carried into the mesh area by the rotation of the gears. Why is it any worse to spray oil under modest pressure where the gears mesh?
Scott
pcar916
post Jul 7 2009, 09:09 AM
Is that a Lola?
QUOTE(stownsen914 @ Jul 7 2009, 06:00 AM) *
Scott
The level is lowered during running since a lot of it is up in the gear train and on the top and sides.
Most of the oil is spun off anyway and a thin film is all you want. If oil is forced into the mesh a lot more oil can't spin off fast enough, and can't compress either, so the gears are forced apart more than they were designed for. With the R&P, this means at the very least, that the carrier bearings are loaded more than they should be. The other gears would be the same, higher bearing loads.
I don't know if it would be enough to break teeth, but it would certainly run hotter... and cool is good.
At worst I suppose a mag case could be compromised. This might make a difference in an early 915 case with a 2-piece bearing plate and an un-reinforced side cover. I have two of those transaxles. No racer would use them use them without the updated parts, but someone else might.
stownsen914
post Jul 8 2009, 05:30 AM
QUOTE(pcar916 @ Jul 7 2009, 11:09 AM) *
Scott
If this is true, then does it mean that there isn't any point in having a spray bar? It would seem that passive sloshing of oil would be the preferable lubrication method ...
Scott
pcar916   Mocal vs Tilton oils cooler pumps   Jul 6 2009, 08:21 AM
ArtechnikA   I'm adding a cooler and pump to my transmissi...   Jul 6 2009, 09:00 AM
pcar916   I haven't tested the transaxle fluid temps in...   Jul 6 2009, 09:11 AM
ArtechnikA   265°F degree transmission fluid scares me no mat...   Jul 6 2009, 09:17 AM
pcar916   265°F degree transmission fluid scares me no ma...   Jul 6 2009, 10:07 AM
puff adder   I've read about cooling systems with spray bar...   Jul 6 2009, 06:47 PM
ArtechnikA   I've read about cooling systems with spray ba...   Jul 6 2009, 07:25 PM
puff adder   Thanks for the info. I guess I'm more intere...   Jul 6 2009, 08:39 PM
pcar916   You could do it if you ignored squirters on the ge...   Jul 6 2009, 09:21 PM
stownsen914   If you decide to install squirters, don't mak...   Jul 7 2009, 08:00 AM
pcar916   If you decide to install squirters, don't ma...   Jul 7 2009, 09:09 AM
stownsen914   [quote name='stownsen914' post='1189240' date='Ju...   Jul 8 2009, 05:30 AM
john rogers   I would recommend calling several shops that RACE ...   Jul 7 2009, 12:15 AM
Downunderman   If you are running a 6 a sportomatic pump off the ...   Jul 7 2009, 12:48 AM
pcar916   Downunderman... - I have a power take-off on the ...   Jul 7 2009, 09:38 AM
john rogers   If you hook up the plumbing system you might be su...   Jul 7 2009, 10:26 AM
pcar916   If you hook up the plumbing system you might be s...   Jul 7 2009, 11:03 AM
john rogers   I guess I am getting old as I forgot to mention to...   Jul 7 2009, 11:34 AM
pcar916   I guess I am getting old as I forgot to mention t...   Jul 7 2009, 03:44 PM
jt914-6   I've got a brass 1/2" female one way valv...   Jul 7 2009, 05:14 PM
pcar916   I've got a brass 1/2" female one way val...   Jul 7 2009, 05:48 PM
Downunderman   I have been using the sporto pump for a couple of ...   Jul 7 2009, 05:28 PM
pcar916   I have been using the sporto pump for a couple of...   Jul 7 2009, 06:21 PM
pcar916   Spraying on the individual gears is good, just not...   Jul 8 2009, 07:38 AM
stownsen914   Spraying on the individual gears is good, just no...   Jul 9 2009, 05:12 AM
Downunderman   Ron, You should be able to find a sporto pump lay...   Jul 8 2009, 09:03 PM
john rogers   Remember, if the lube and cooler pump is engine dr...   Jul 8 2009, 11:14 PM
puff adder   Where is the cooler itself usually mounted? Did ...   Jul 9 2009, 09:44 AM
ArtechnikA   Where is the cooler itself usually mounted? Cooli...   Jul 9 2009, 11:07 AM
pcar916   Excellent discussion and why I like this forum. I...   Jul 9 2009, 11:12 AM
Downunderman   Here are some photos for posterity. Before it had...   Jul 10 2009, 03:21 PM
pcar916   You realize your car is far too clean right? Nice ...   Jul 11 2009, 08:02 AM
maf914   I remember reading in 24:16: Le Mans 24 Hours that...   Jul 15 2009, 03:17 PM
john rogers   Here are a couple of picts of the setup I had and ...   Jul 15 2009, 03:31 PM
pcar916   Simple... fan underneath or scoop only?   Jul 15 2009, 10:21 PM
john rogers   An axial boat ventilation fan was added after thes...   Jul 16 2009, 12:55 AM
pcar916   An axial boat ventilation fan was added after the...   Jul 16 2009, 07:54 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 03:16 PM
