Fuel Line / EFI Installation, Alum / Braided Lines & Holley EFI on V8 |
jridder |
Feb 5 2004, 07:33 PM
Member Group: Members Posts: 136 Joined: 5-May 03 From: Sunnyvale, CA Member No.: 656 |
Here's some pictures of my installation of aluminum and braided fuel lines and a Holley Commander 950 TBI system on my V8.
First pic shows the 3/8" aluminum fuel lines in the area under the gas tank. Attached image(s) |
jridder |
Feb 7 2004, 09:31 PM
>Can the return line go in the top of the tank?
On other cars being retrofitted with EFI, they run the return line into an adapter that goes in the filler hose. Of course that wouldn't work on a 914. 914's already have the return fittings anyways, so I can't see why one would need to run it to the top of the tank. There is some advantage to having the return line close to the pickup so that you don't circulate the entire contents of the gas tank and heat up all of the fuel. >Did you weld the male AN fitting to the existing fuel tank outlet after cleaning? I welded them on before having the tank cleaned. There is another thread with pictures of that. >Looking at your distributor it looks like it could be a tooth or 2 off on your timing. It seemed to be OK when I checked it with my timing light. The previous owner had the flywheel marked at TDC. I replaced the vacuum/mechanical advance distributor with a computer controlled distributor. |
Lo-Fi Version | Time is now: 11th June 2024 - 12:23 PM |
