> Lost the spring that goes between dizzy and dizzy drive, Now its found and fixed!
VaccaRabite
post Jul 18 2009, 08:57 PM
En Garde!
I was so close to getting my motor started...
I was getting ready to put my mallory into place. Put in the spring, but it did not go into the divot right. So I put my finger into the hole to grab it, and the freaking spring disappeared.
I look in there with a light, and there is a hole that goes into the case that the spring has somehow gone into. Dr Evil and I tried to retrieve it with a magnet, but we can't locate the spring.
So - what is that hole? Where does it lead to? Is the spring sitting in a galley somewhere, or has it gone down into the pan. Will I find it if I pull the tuna can off and the inspection plate? I just spent a week building this motor, and an am trying to find time on friday and saturday night after my son goes to sleep to get it running. Dropping the motor for a ANOTHER rebuild is an option, but it is likely one that will table my car until I am done with grad school, or I stop being mad at it/myself.
Zach
VaccaRabite
post Jul 20 2009, 08:49 PM
En Garde!
I'm not in nearly the foul mood that I was in Saturday night. Skipping class, taking a nap, having a nice dinner with Erin and Theo like a proper family should, and then watching the episode of Top Gear that I downloaded on Sunday did miles to improve my mood.
Not that I am turning down the help. If you are around, I'll take it gladly. 'Specially putting the clutch cable back on is a two person job, and Erin does not go into the garage to work on cars, unless it is her car that I am working on.
Zach
Vacca Rabite   Lost the spring that goes between dizzy and dizzy drive   Jul 18 2009, 08:57 PM
Dr Evil   :jenny:   Jul 18 2009, 10:23 PM
scotty b   :headbang: :headbang: :headbang: :chair: :chai...   Jul 18 2009, 10:27 PM
Vacca Rabite   I'm going to cock up a wheel and rotate the en...   Jul 18 2009, 10:34 PM
Dr Evil   Dont you have another block up in the attic that y...   Jul 18 2009, 11:23 PM
Vacca Rabite   It is a drain that goes to the forward sump after ...   Jul 19 2009, 10:07 AM
Dr Evil   I'll fix it if you cant get to it first. Dont ...   Jul 19 2009, 10:09 AM
904svo   Remove the taco plate and fish with a magnet you c...   Jul 19 2009, 10:11 AM
Dr Evil   Zach, might I recommend a hand transplant? Or, at ...   Jul 19 2009, 10:16 AM
r_towle   I think if you remove the plate that holds the oil...   Jul 19 2009, 03:56 PM
McMark   Could have gone down near the taco plate. A small...   Jul 19 2009, 04:33 PM
Dr Evil   He has been quite today. I hope he got it, and tha...   Jul 19 2009, 05:34 PM
jsayre914   did this happen right after i left??? :blink:   Jul 19 2009, 06:03 PM
Dr Evil   yup   Jul 19 2009, 07:23 PM
Vacca Rabite   No, I have not gotten it. I did jack one side up ...   Jul 19 2009, 07:43 PM
Dr Evil   Ya, I am about to finish up my two papers. I would...   Jul 19 2009, 07:45 PM
Vacca Rabite   So I skipped class and went into the garage tonigh...   Jul 20 2009, 08:32 PM
Dr Evil   Need help? I will see when I have time to come dow...   Jul 20 2009, 08:41 PM
Vacca Rabite   I'm not in nearly the foul mood that I was in ...   Jul 20 2009, 08:49 PM
ghuff   Last time something like this happened, my partner...   Jul 20 2009, 08:57 PM
Dr Evil   I will not be dropping the engine. That is for arm...   Jul 20 2009, 09:50 PM
Vacca Rabite   Armatures? I guess you could call the jack an arm...   Jul 20 2009, 10:05 PM
Dr Evil   Sure, wise ass. At least I am not trying to go aft...   Jul 20 2009, 10:07 PM
Vacca Rabite   GOT IT! Well, Dr Mike got it. I came out and...   Jul 23 2009, 08:53 PM
Jake Raby   The paper gasket between the pump and cover?? Or t...   Jul 23 2009, 08:59 PM
Vacca Rabite   Case and pump. But I was reading on your site las...   Jul 24 2009, 07:38 AM
type11969   Nice work!   Jul 24 2009, 09:14 AM
Dr Evil   Good work researching the gasket, Zach. Now you ca...   Jul 24 2009, 12:04 PM
Vacca Rabite   Pump is back in and sealed. Engine went back to T...   Jul 24 2009, 07:25 PM
Dr Evil   I'll be over tomorrow to futz with the bus aft...   Jul 24 2009, 07:43 PM
- Lo-Fi Version Time is now: 1st July 2025 - 06:52 AM
