> Lost the spring that goes between dizzy and dizzy drive, Now its found and fixed!
VaccaRabite
post Jul 18 2009, 08:57 PM
En Garde!
I was so close to getting my motor started...
I was getting ready to put my mallory into place. Put in the spring, but it did not go into the divot right. So I put my finger into the hole to grab it, and the freaking spring disappeared.
I look in there with a light, and there is a hole that goes into the case that the spring has somehow gone into. Dr Evil and I tried to retrieve it with a magnet, but we can't locate the spring.
So - what is that hole? Where does it lead to? Is the spring sitting in a galley somewhere, or has it gone down into the pan. Will I find it if I pull the tuna can off and the inspection plate? I just spent a week building this motor, and an am trying to find time on friday and saturday night after my son goes to sleep to get it running. Dropping the motor for a ANOTHER rebuild is an option, but it is likely one that will table my car until I am done with grad school, or I stop being mad at it/myself.
Zach
ghuff
post Jul 20 2009, 08:57 PM
This is certainly not what I expected down here.
Last time something like this happened, my partner decided he would risk it and swore he heard the m6x1 nut he dropped hit the ground.
It did not, it went into his intake runner and he luckily only munched 1 valve. Miraculously it was only a valve and the forged custom pistons were fine.
Lesson learned about just jamming it together to get it to run then. Glad you came to your senses about pulling it back apart.
Vacca Rabite   Lost the spring that goes between dizzy and dizzy drive   Jul 18 2009, 08:57 PM
Dr Evil   :jenny:   Jul 18 2009, 10:23 PM
scotty b   :headbang: :headbang: :headbang: :chair: :chai...   Jul 18 2009, 10:27 PM
Vacca Rabite   I'm going to cock up a wheel and rotate the en...   Jul 18 2009, 10:34 PM
Dr Evil   Dont you have another block up in the attic that y...   Jul 18 2009, 11:23 PM
Vacca Rabite   It is a drain that goes to the forward sump after ...   Jul 19 2009, 10:07 AM
Dr Evil   I'll fix it if you cant get to it first. Dont ...   Jul 19 2009, 10:09 AM
904svo   Remove the taco plate and fish with a magnet you c...   Jul 19 2009, 10:11 AM
Dr Evil   Zach, might I recommend a hand transplant? Or, at ...   Jul 19 2009, 10:16 AM
r_towle   I think if you remove the plate that holds the oil...   Jul 19 2009, 03:56 PM
McMark   Could have gone down near the taco plate. A small...   Jul 19 2009, 04:33 PM
Dr Evil   He has been quite today. I hope he got it, and tha...   Jul 19 2009, 05:34 PM
jsayre914   did this happen right after i left??? :blink:   Jul 19 2009, 06:03 PM
Dr Evil   yup   Jul 19 2009, 07:23 PM
Vacca Rabite   No, I have not gotten it. I did jack one side up ...   Jul 19 2009, 07:43 PM
Dr Evil   Ya, I am about to finish up my two papers. I would...   Jul 19 2009, 07:45 PM
Vacca Rabite   So I skipped class and went into the garage tonigh...   Jul 20 2009, 08:32 PM
Dr Evil   Need help? I will see when I have time to come dow...   Jul 20 2009, 08:41 PM
Vacca Rabite   I'm not in nearly the foul mood that I was in ...   Jul 20 2009, 08:49 PM
ghuff   Last time something like this happened, my partner...   Jul 20 2009, 08:57 PM
Dr Evil   I will not be dropping the engine. That is for arm...   Jul 20 2009, 09:50 PM
Vacca Rabite   Armatures? I guess you could call the jack an arm...   Jul 20 2009, 10:05 PM
Dr Evil   Sure, wise ass. At least I am not trying to go aft...   Jul 20 2009, 10:07 PM
Vacca Rabite   GOT IT! Well, Dr Mike got it. I came out and...   Jul 23 2009, 08:53 PM
Jake Raby   The paper gasket between the pump and cover?? Or t...   Jul 23 2009, 08:59 PM
Vacca Rabite   Case and pump. But I was reading on your site las...   Jul 24 2009, 07:38 AM
type11969   Nice work!   Jul 24 2009, 09:14 AM
Dr Evil   Good work researching the gasket, Zach. Now you ca...   Jul 24 2009, 12:04 PM
Vacca Rabite   Pump is back in and sealed. Engine went back to T...   Jul 24 2009, 07:25 PM
Dr Evil   I'll be over tomorrow to futz with the bus aft...   Jul 24 2009, 07:43 PM
- Lo-Fi Version Time is now: 1st July 2025 - 07:16 AM
