> Shock Options full race, What are you running?
Heeltoe914
post Jul 17 2009, 11:59 AM
Setup is full simi tube car 1775 appox, 10 and 12 LSD Boxster brakes Combo of high speed tracks and AX. Driving.
Hi guys starting stage three of the upgrades to my Spyder racecar. I am planning to add Adjustable front and rear shocks. The front should not be such a big deal the shocks on the car now are made by a Company called Carrera Shocks. The front’s inserts are much shorter than a Carrera or SC size inserted shock. It’s about 10.5 inch long. The rears are short about 12.5 “.
If you notice the rear shocks are inverted, I would like to find something that will mount with the shock bolt and damper location. What makes finding a replacement a challenge is that the stub that is welded onto my rear shocks is not commonly done and would have to be done before the shock is constructed. I would think that there are other ways of getting a inverted shock on a 914 using stock mounting locations.
Advice or suggestion welcomed.
Part two;
Another question I have is if you have a track only racecar that ran as a high output four banger with a very good setup, than converted it to a 3.6 which adds some weight & HP what guess would you make on how much to go up on front and or rear spring rates???
I am thinking 50pds per corner just for the weight but I need to add in the hard acceleration and cornering as well. What has anyone here tried?
Joe Ricard
post Jul 24 2009, 09:15 PM
CUMONIWANNARACEU
Dang Blake that is nearly exactly how I mounted the lower eye of my shocks. And I never seen your set up before.
Heeltoe914   Shock Options full race   Jul 17 2009, 11:59 AM
Randal   What are you going to be doing with the car? Driv...   Jul 17 2009, 01:01 PM
Phoenix 914-6GT   JRZs are the best you can get for the 914   Jul 17 2009, 02:09 PM
Heeltoe914   Randel its a full out chop top race car.   Jul 17 2009, 02:25 PM
Randal   Randel its a full out chop top race car. OK, r...   Jul 17 2009, 04:06 PM
Dan (Almaden Valley)   Randal, it is the EX-Bill Newlin hot rod with a 3....   Jul 17 2009, 06:12 PM
Randal   Randal, it is the EX-Bill Newlin hot rod with a 3...   Jul 17 2009, 07:20 PM
Heeltoe914   Well Randell you think like I. I have tried to fi...   Jul 17 2009, 10:55 PM
Joe Ricard   Well since it is a full out race car get full out ...   Jul 18 2009, 06:27 AM
Heeltoe914   Thanks Joe I did some looking tonight on Ebay and...   Jul 19 2009, 12:20 AM
Joe Ricard   Aluminum large body threaded 7"shock. 147# s...   Jul 19 2009, 05:52 AM
Heeltoe914   Aluminum large body threaded 7"shock. 147# ...   Jul 19 2009, 10:32 AM
Joe Ricard   yes inverted. you will need a bracket to mount it ...   Jul 19 2009, 02:19 PM
bam914   I have an extra set of Dynamic Suspension canister...   Jul 22 2009, 08:09 PM
Heeltoe914   Thanks for the offer can you drop me a PM I think ...   Jul 22 2009, 09:44 PM
Joe Ricard   Dang Blake that is nearly exactly how I mounted th...   Jul 24 2009, 09:15 PM
bam914   Those lower mounts were made by Carrera when they ...   Jul 24 2009, 09:23 PM
stewteral   Setup is full simi tube car 1775 appox, 10 and 1...   Sep 19 2009, 12:45 PM
bam914   Look up a Koni 8611 series. It is a double adjust...   Sep 19 2009, 02:37 PM
Britain Smith   Blake, do you have a picture of the front assembly...   Oct 16 2009, 02:58 PM
brant   what is the company name that took over Carrera......   Oct 18 2009, 10:55 PM
Heeltoe914   what is the company name that took over Carrera.....   Oct 19 2009, 12:05 AM
HAM Inc   QA-1 now owns Carrera. I don't know any road r...   Oct 19 2009, 04:15 PM
Racer Chris   He is a big Ohlins fan now. I'm going to i...   Oct 19 2009, 09:16 PM
Phoenix 914-6GT   He is a big Ohlins fan now. I'm going to ...   Oct 20 2009, 04:35 AM
Racer Chris   I'm going to install Ohlins LMJ 7" stro...   Dec 12 2009, 03:18 AM
Randal   [quote name='Phoenix 914-6GT' post='1228097'...   Dec 14 2009, 01:40 PM
Heeltoe914   [quote name='Racer Chris' post='1227977' date='Oc...   Oct 20 2009, 03:33 PM
Racer Chris   The white FP car already has them, taken off Thors...   Oct 20 2009, 04:38 PM
Britain Smith   What is the cost on these? -Britain   Oct 20 2009, 05:09 PM
Racer Chris   What is the cost on these? -Britain about ...   Oct 22 2009, 05:24 AM
Racer Chris   What is the cost on these? -Britain About ...   Dec 12 2009, 03:20 AM
puff adder   I'm not sure if they cross-fit on a 914, but t...   Oct 20 2009, 08:49 PM
Joe Ricard   http://www.jrzusa.net/prices/jrz_prices.pdf Price...   Oct 21 2009, 07:06 AM
Britain Smith   http://www.jrzusa.net/prices/jrz_prices.pdf Pric...   Oct 23 2009, 03:35 PM
Heeltoe914   Ya right? maybe in my next life. Thoose are the ...   Oct 21 2009, 08:18 PM
euro911   ... Those are the part numbers right? :lol: Fun...   Oct 22 2009, 01:22 AM
Racer Chris   [quote name='Heeltoe914' post='1228902' date='Oct...   Oct 22 2009, 05:26 AM
euro911   Boges are the best value if you aren't using t...   Oct 23 2009, 11:04 PM
Racer Chris   ... worth the extra $ ? They are if you wan...   Oct 24 2009, 07:56 PM
Britain Smith   Are there JRZ shocks from a different application ...   Oct 23 2009, 03:36 PM
Phoenix 914-6GT   Are there JRZ shocks from a different application...   Oct 23 2009, 04:51 PM
puff adder   My car has JRZ shocks. I'll take some pics a...   Oct 23 2009, 06:39 PM
puff adder   Here's some pics. Photography isn't my fo...   Oct 23 2009, 07:37 PM
Heeltoe914   Here's some pics. Photography isn't my f...   Oct 23 2009, 10:18 PM
puff adder   Thanks very much. The guy who built my car was an ...   Oct 24 2009, 05:58 AM
Heeltoe914   Thanks very much. The guy who built my car was an...   Oct 24 2009, 07:26 PM
Joe Ricard   Chris I just love the way you fixed the rear shoc...   Dec 13 2009, 05:19 PM
Racer Chris   They machined nicely. I used my old worn out P...   Dec 13 2009, 06:19 PM
ME733   :popcorn: ...Chris ...I have a set of CARRERA shoc...   Dec 14 2009, 09:17 AM
Racer Chris   :popcorn: ...Chris ...I have a set of CARRERA sho...   Dec 14 2009, 12:13 PM
ME733   :popcorn: :popcorn: ...Chris ...I have a set of ...   Dec 14 2009, 04:12 PM
Joe Ricard   Matching springs to shocks is a bit backwards. Ma...   Dec 14 2009, 10:46 AM
Joe Ricard   Randal, you have shocks up front? Us poor guys ...   Dec 14 2009, 03:03 PM
Randal   Randal, you have shocks up front? Us poor guys...   Dec 14 2009, 05:16 PM
SirAndy   We're running the Fox shocks from Smart Racing...   Dec 14 2009, 06:01 PM
SirAndy   Wait, it says right there "now available for ...   Dec 14 2009, 06:04 PM
Randal   Wait, it says right there "now available for...   Dec 14 2009, 06:09 PM
SirAndy   He swears by them. He sells them too ... :D Th...   Dec 14 2009, 06:27 PM
J P Stein   Hayden says the Fox are way too stiff for a 914 AX...   Dec 14 2009, 07:09 PM
SirAndy   Hayden says the Fox are way too stiff for a 914 A...   Dec 14 2009, 07:15 PM
J P Stein   Hayden says the Fox are way too stiff for a 914 ...   Dec 14 2009, 09:17 PM
Randal   [quote name='SirAndy' post='1250594' date='Dec 14...   Dec 14 2009, 10:28 PM
Racer Chris   OK gentlemen, what front shocks will work best wi...   Dec 15 2009, 09:29 AM
Racer Chris   Thats just one of the reasons I'm going with t...   Dec 14 2009, 08:46 PM
Joe Ricard   Get the fox shocks and have them re-valved for the...   Dec 15 2009, 05:57 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 03:35 PM
