| kenshapiro2002 |
Jul 24 2009, 06:39 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,486 Joined: 23-July 09 From: Bawlmer, MD Member No.: 10,598 Region Association: MidAtlantic Region |
Just brought the green machine back from CT this afternoon. After filling her up, she started to starve under load (trying to accelerate above 3,500 RPM...getting up a hill, etc.) so badly at one point I had to pull off the highway...she was dying. After sitting for 10-15 minutes, she fired up and was alright for another half hour. Then it all repeated. After the second rest she made it all the way back to Baltimore and ran beautifully for 90% of the time. I could sense a little starvation once in awhile.
I'm a shade tree mechanic at best, but my guess is that even though the seller (A Porsche tech) said the fuel tank was amazingly clean and needed nothing after being stored for 20 years, the fuel filter was getting clogged, and perhaps sitting for a while let things "settle". The seller suspects points. Any opinions? Thanks in advance, Ken |
| McMark |
Jul 24 2009, 07:48 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
Take a flashlight and have a look into the gas tank through the filler. At the correct angle you can see the pickup tube. Look for garbage.
Check the filter, and I'd replace it just so I know exactly how old it is. A standard tune up is a good way to set a 'baseline'. Adjust the valves, set the timing, check the dwell, etc. Does this car have fuel injection, or a carburetor? What year is it? |
| kenshapiro2002 |
Jul 25 2009, 07:41 AM
Good point, but being a "shade tree mechanic" at best. how do I know what parameters to use on a tune up? The engine has been modified and I'm not 100% sure of the mods. Aren't the numbers for a tune up (even plugs) going to change since it was a 1.7 but now has a big bore kit? Since it was FI and now has twin Webers? I;m also guessing (hoping) the cam was changed when that car went to carbs. Is it a good idea to find a local type 4 "guru" to tune it the first time and eductae me?
Ken Take a flashlight and have a look into the gas tank through the filler. At the correct angle you can see the pickup tube. Look for garbage. Check the filter, and I'd replace it just so I know exactly how old it is. A standard tune up is a good way to set a 'baseline'. Adjust the valves, set the timing, check the dwell, etc. Does this car have fuel injection, or a carburetor? What year is it? |
| ArtechnikA |
Jul 25 2009, 09:22 AM
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
Good point, but being a "shade tree mechanic" at best. how do I know what parameters to use on a tune up? The engine has been modified and I'm not 100% sure of the mods. Aren't the numbers for a tune up (even plugs) going to change Not as much as you might think. If the plugs need to be different, the different plugs should be in there now. Pull 'em and have a look. If they're Bosch, and 20 years old, you may have to find a cross-reference (Bosch changes their numbering scheme with the tides...) Old plug wires are presumptively bad. If it has the original ignition, get new Bosch (accept no substitutes) points, condenser, cap, and rotor. Set the point gap to 0.016" and static-time to some nominal value (maybe 6ยบ BTDC). After you're sure all the basics are working properly you can go for the full timing-light full-advance method. Clean ALL the jets - you'll be amazed what can crawl into the main jet stack over time. Weber idle jets are notorious for clogging under even the best of conditions. Use only good, fresh gas - bad gas kills engines ! Unless you have hydraulic lifters (unlikely, but check, 'cause ya never know...) the valve lash numbers don't change much - there's a bunch of basic tune up threads with those numbers - I don't try to keep up with them since I don't have a T-IV... |
kenshapiro2002 Starving Under Load? Jul 24 2009, 06:39 PM
ArtechnikA
Ignit... Jul 24 2009, 07:38 PM
orange914 from what you said, sounds like your staring for f... Jul 24 2009, 07:45 PM
r_towle
Take a flashlight and have a look into the gas ta... Jul 24 2009, 08:34 PM
kenshapiro2002 1970, big bore kit to 2.0, twin webers.
Ken
Tak... Jul 24 2009, 10:26 PM
Rand
I guess the beer is taking affect, because I... Jul 24 2009, 10:51 PM
McMark Vapor lock is a good possibility. While your doin... Jul 24 2009, 11:43 PM
r_towle Carbs dont do well with old fuel in them.
At the m... Jul 24 2009, 11:56 PM
Vacca Rabite The valve lash for a 1.7 was .006 intake and .006 ... Jul 25 2009, 11:11 AM
orange914 pertronix electronic ign. conversion is a very goo... Jul 25 2009, 01:54 PM
kenshapiro2002 Thanks folks!
Ken Jul 25 2009, 02:03 PM
Rand Ken, reading your original post, it looks like you... Jul 25 2009, 02:05 PM
kenshapiro2002 Yeah...after sitting for 20 years, the Porsche tec... Jul 25 2009, 07:46 PM
charliew There is a chance the techron will thin and break ... Jul 25 2009, 05:49 PM
Eddie914 "After filling up" .... Bad gas? It wi... Jul 25 2009, 06:26 PM
kenshapiro2002 Eddie,
Here I am , three months later, to tell yo... Oct 22 2009, 05:46 PM
crash914 hmmm carbs, I was going to go with trigger points ... Jul 25 2009, 07:50 PM
kenshapiro2002 Never heard of "trigger points". Are we ... Jul 26 2009, 09:32 AM
Rand
Never heard of "trigger points". Are we... Jul 26 2009, 10:53 AM
kenshapiro2002 Well...she's doing it all the time now. The fu... Aug 10 2009, 03:16 PM
kenshapiro2002 How difficult is this? Do I need a weber book to f... Aug 10 2009, 03:18 PM
crash914 trigger points are used in fuel injection engines ... Jul 26 2009, 10:57 AM
Kirmizi http://www.carburetorclinic.com/weber_tech.htm
Try... Aug 10 2009, 03:26 PM
nycchef
Tr... Aug 11 2009, 08:01 AM
jmill After sitting for so long you need to go through t... Aug 11 2009, 02:36 PM
kenshapiro2002 Thanks all.
Ken
After sitting for so long you ne... Aug 11 2009, 05:18 PM
r_towle pull them off.
Box them up.
Send them to Art.
htt... Aug 11 2009, 06:26 PM
kenshapiro2002 Just drove it like I stole it and it ran better, a... Aug 14 2009, 05:11 PM
r_towle If you get a gallon can of carb cleaner so you can... Aug 14 2009, 06:56 PM
jmill 1 -Does it scream away in the first couple of gear... Aug 14 2009, 08:27 PM
kenshapiro2002 1...No. In fact it does worse in first than any ot... Aug 14 2009, 08:42 PM
seebobgo Let the spending begin. You got to find a good sho... Aug 15 2009, 06:13 PM
kenshapiro2002 Shop my ass...anything a "shop" can do I... Aug 15 2009, 07:05 PM
kenshapiro2002 Alright...so I've had the rebuild kits for a w... Aug 18 2009, 10:26 PM
r_towle
Alright...so I've had the rebuild kits for a ... Aug 18 2009, 10:51 PM
jmill To do it right, yes. There isn't much to them... Aug 18 2009, 10:52 PM
kenshapiro2002 So...just went out to drive her hard again. I gues... Aug 19 2009, 05:56 PM
jmill Yes it's that simple if the tank is empty. Do... Aug 19 2009, 07:21 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 06:40 PM |
