FourBlades |
From Wreck to Rockin ![]() ![]() ![]() ![]() Group: Members Posts: 2,056 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States ![]() ![]() |
I was test fitting my doors before painting them and noticed this:
Driver side. ![]() Passenger side. Attached image(s) ![]() |
tracks914 |
Canadian Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,083 Joined: 15-January 03 From: Timmins, Ontario, Canada Member No.: 153 Region Association: None ![]() ![]() |
Yours looks easy to fix.
Your door is too low at the back. You can see this in the lines at the top and bottom. Try raising your striker plate at bit and put some shims under your bottom door hinge. You might want to try a washer between the hinge and the pillar just to test this theory. Raising your door (at the back) will increase the gap at the bottom and hopefully close it a bit at the top. |
Lo-Fi Version | Time is now: 1st August 2025 - 06:32 PM |
