> Acquired a 914-Need Your Help... She's Dead, Sitting for 20+years...Help me bring life with little $$
tabs914
post Jul 29 2009, 08:44 AM
Advertise Your Drive...
Update on 10/11/09: I ditched the old motor with a new one. So all the posts to page 4 I believe are for the old motor. I do have some issues that relate to the new motor on Page 5.... (IMG:style_emoticons/default/biggrin.gif) Thanks.
OK... first thing the fuel system and harness were removed because the previous owner wanted to convert it to a duel carb set-up. So I put the FI back in. I bought a fresh battery, oil, filters and replaced the all the fuel lines plus vacuum lines.
Now I want to try to start the darn thing and all I get is a "click" noise from the starter... so i jack the left side leaving the right side on the ground and put it in 5th gear. I turn the tire front the back a few times in either direction. I try to start it agian... "click". So I do the opposite side, but this time on the right i can't move the tire at all... well it will move 2-3", but thats it. Brakes are free btw. I have seen on the www that "Miricle Oil" down the plug holes will free up the pistons if they are siezed. I just dont understand that I can rotate one side and not the other. Thanks for your help... (IMG:style_emoticons/default/rolleyes.gif)
Update: Found Water in the Oil - Lots! (IMG:style_emoticons/default/confused24.gif) What to do? Rebuild? Lube the hell out of it? More Mystery oil? (IMG:style_emoticons/default/blink.gif)
Cupomeat
post Jul 30 2009, 03:37 PM
missing my NY 914 in VA
Ok, that sounds correct to me.
if the one wheel is on the ground and the transmission is in 5th (or any gear) you will be attempting to turn over the engine when turning the wheel/tire.
This should be the same for all 5 plus reverse gears, is it not?
Given the click of the starter, the inability to turn the motor over using 5th gear and a wheel on the ground, I'd say the motor is seized.
Pull it and see what you find. I doubt the Marvel Mystery oil will do enough for you to start this puppy.
Honestly, I think you have enough ambiguities in the condition of things to warrent a drivetrain pull and inspection of engine and transmission.
BTW, what is the transmission code (found on the bottom lateral rib of the gear box (starts with 901).
Thanks and pulling the motor/trans is a good thing. You can learn as well as find out what is wrong at the same time.
tabs914   Acquired a 914-Need Your Help... She's Dead   Jul 29 2009, 08:44 AM
mojorisen914   :ttiwwp:   Jul 29 2009, 09:04 AM
DonnyT   if you can get a socket and breaker bar onto the f...   Jul 29 2009, 09:08 AM
tabs914   The car came with an extra starter... i replaced i...   Jul 29 2009, 09:29 AM
Randal   The car came with an extra starter... i replaced ...   Jul 29 2009, 09:34 AM
jim_hoyland   Rear wheel bearings may require replacement front ...   Jul 29 2009, 09:36 AM
tabs914   I can tell the resistance is internal not from the...   Jul 29 2009, 09:49 AM
ericread   Check your grounds. The 914 is notorious for lett...   Jul 29 2009, 09:51 AM
Cupomeat   Ok, on the subject of rotating the left side, but ...   Jul 29 2009, 10:08 AM
Heeltoe914   Your getting allot of great tips put your trucks o...   Jul 29 2009, 10:17 AM
carr914   It is not unusual for a new battery to not have a ...   Jul 29 2009, 10:51 AM
ConeDodger   Grounds.   Jul 29 2009, 11:09 AM
Vacca Rabite   Check grounds . Try a different (known good) batt...   Jul 29 2009, 11:30 AM
tabs914   Thank you all... I havent tried both wheels off th...   Jul 29 2009, 12:48 PM
Phoenix 914-6GT   Don't miss the ground strap just above the tra...   Jul 29 2009, 01:02 PM
pktzygt   I've got something that stumped me for a bit. ...   Jul 29 2009, 01:30 PM
tabs914   I've got something that stumped me for a bit....   Jul 29 2009, 02:14 PM
Hammy   Check and clean that tranny ground and also make s...   Jul 29 2009, 02:01 PM
Cupomeat   Ok, good info, so that pretty much starts the prob...   Jul 29 2009, 05:06 PM
Kansas 914   OK... first thing the fuel system and harness wer...   Jul 29 2009, 07:27 PM
r_towle   Pull the tranny out. See if you can turn the motor...   Jul 29 2009, 07:32 PM
rick 918-S   A couple good ideas here. Mike is hinting at a li...   Jul 29 2009, 07:40 PM
tabs914   This is great... thank you all. OK so I get home w...   Jul 30 2009, 08:42 AM
RJMII   did you pull the right rear wheel and check the co...   Jul 30 2009, 02:15 PM
tabs914   did you pull the right rear wheel and check the c...   Jul 30 2009, 03:21 PM
Cupomeat   Ok, that sounds correct to me. if the one wheel i...   Jul 30 2009, 03:37 PM
tabs914   Ok, that sounds correct to me. if the one wheel ...   Jul 30 2009, 04:17 PM
type2man   I'm thinking the clutch disc could be stuck on...   Jul 30 2009, 04:06 PM
tabs914   I'm thinking the clutch disc could be stuck o...   Jul 30 2009, 04:15 PM
DonnyT   You should be able to turn the engine over by hand...   Jul 30 2009, 06:48 PM
DonnyT   Had a problem once with a bad connection on the se...   Jul 30 2009, 06:52 PM
tabs914   Found evidence of water in the oil... I removed th...   Jul 31 2009, 11:00 AM
type47   Found evidence of water in the oil... I removed t...   Jul 31 2009, 05:00 PM
type47   Well, you say it's been sitting 20 years and f...   Jul 31 2009, 04:56 PM
r_towle   water gets in for lots of reasons. Is it alot of w...   Jul 31 2009, 04:57 PM
tabs914   water gets in for lots of reasons. Is it alot of ...   Jul 31 2009, 05:07 PM
r_towle   can you rotate the motor? Here is my test. If you...   Jul 31 2009, 05:08 PM
tabs914   can you rotate the motor? Here is my test. If yo...   Jul 31 2009, 05:26 PM
tabs914   Not by hand   Jul 31 2009, 05:09 PM
r_towle   I added a bit more detail to what I mean "by ...   Jul 31 2009, 05:13 PM
tabs914   Hey Rich...thank you for your time. :D I can rot...   Jul 31 2009, 05:17 PM
tabs914   :Qarl: Engine finally broke loose today... now I c...   Aug 4 2009, 06:59 PM
tabs914   I got it crainking :Qarl: It was the grounds... ...   Aug 7 2009, 12:53 AM
McMark   A little PB Blaster into the fuel pump can sometim...   Aug 7 2009, 03:09 AM
Vacca Rabite   If the fuel pump was seized, would it be reliable ...   Aug 7 2009, 08:57 AM
kwales   Sometimes it's varnish left over form dehydrat...   Aug 7 2009, 09:17 AM
tabs914   Thanks for the advice... I will try it. It can...   Aug 7 2009, 10:04 AM
tabs914   OK I got the pump working :Qarl: Now Im not gett...   Aug 9 2009, 02:17 AM
cwpeden   go to this site for FI diagnosis tips, its helped ...   Aug 9 2009, 04:07 AM
tabs914   go to this site for FI diagnosis tips, its helped...   Aug 11 2009, 06:25 PM
McMark   I don't understand what the newest problem is....   Aug 11 2009, 09:02 PM
tabs914   I don't understand what the newest problem is...   Aug 11 2009, 09:25 PM
r_towle   Post a close up pic of the coil wiring. Rich   Aug 11 2009, 09:26 PM
tabs914   Post a close up pic of the coil wiring. Rich I...   Aug 11 2009, 10:11 PM
tabs914   Here are some pics of the car... :D   Aug 11 2009, 09:38 PM
tabs914   some more...   Aug 11 2009, 10:06 PM
McMark   Tracing backwards from the coil, with the key on: ...   Aug 12 2009, 12:01 AM
tabs914   Tracing backwards from the coil, with the key on:...   Aug 15 2009, 11:15 AM
tabs914   well it appears I don't have pin 8 or 9 on the...   Aug 12 2009, 09:21 PM
tabs914   Here are the volt readings with the ignition on. B...   Aug 15 2009, 10:25 AM
Dr Evil   Was your plug messed with? Your coil is correctly ...   Aug 15 2009, 11:33 AM
tabs914   So the green heater wire shouldn't be plugged ...   Aug 15 2009, 11:42 AM
Dr Evil   Ya, that would explain the power on the pin. That ...   Aug 15 2009, 12:00 PM
tabs914   Ya, that would explain the power on the pin. That...   Aug 15 2009, 12:05 PM
Dr Evil   :thumbsup:   Aug 15 2009, 12:07 PM
tabs914   OK... I put a new condenser on and it seems to be ...   Aug 15 2009, 03:51 PM
Dr Evil   What do you mean it wont distribute? How do you kn...   Aug 15 2009, 05:13 PM
tabs914   the plug wire off the coil is creating a spark, bu...   Aug 15 2009, 05:38 PM
Dr Evil   Ah, is the rotor installed? There is no reason oth...   Aug 15 2009, 05:46 PM
tabs914   ok I think im good...I put the tester on it and it...   Aug 15 2009, 05:54 PM
McMark   Mike, this'll have power if the points are cl...   Aug 15 2009, 07:34 PM
Dr Evil   Mark, ya, but he said the power for the blower was...   Aug 15 2009, 08:30 PM
tabs914   Mark, ya, but he said the power for the blower wa...   Aug 17 2009, 09:30 PM
tabs914   :bump:   Aug 18 2009, 08:36 PM
tabs914   Update: I have her starting up but zero idle. What...   Aug 22 2009, 08:45 PM
tabs914   OK... have a vid, the sound is terrible., but here...   Aug 25 2009, 09:56 PM
McMark   I'd check fuel pressure and timing first.   Aug 25 2009, 11:27 PM
tabs914   ***Update*** Ditched the old motor. Oil leaks, rus...   Sep 28 2009, 12:57 PM
tabs914   New Motor Pic   Sep 28 2009, 01:00 PM
Cupomeat   It is hard to tell, but the small threaded holes, ...   Sep 28 2009, 01:28 PM
tabs914   It's off a BMW I don't have the cone on th...   Sep 28 2009, 01:36 PM
Cupomeat   Ah, this makes sense now. These are the Air Injec...   Sep 28 2009, 01:56 PM
tabs914   Ah, this makes sense now. These are the Air Inje...   Sep 28 2009, 01:59 PM
SLITS   Whatever engine you have is a '75-'76. I ...   Sep 28 2009, 02:04 PM
tabs914   Hey if some one knows the length thread and diamet...   Sep 28 2009, 02:10 PM
SLITS   I'll check in in a bit if I can and measure th...   Sep 28 2009, 02:17 PM
SLITS   While possibly not the correct thread, M10 X 1.25...   Sep 28 2009, 02:56 PM
Thomas J Bliznik   While possibly not the correct thread, M10 X 1.2...   Oct 11 2009, 03:59 PM
tabs914   I have been working on the brakes for the last cou...   Oct 11 2009, 10:35 AM
tabs914   I will elaborate what I have done so far... 1. Ch...   Oct 11 2009, 11:34 AM
tabs914   :bump:   Oct 11 2009, 03:03 PM
tod914   Did you reinspect your points to see if they are f...   Oct 11 2009, 03:33 PM
tabs914   Points look good...I am getting spark. I checked p...   Oct 11 2009, 06:13 PM
tabs914   :bump: Bump   Oct 12 2009, 02:20 PM
Gint   Update on 10/11/09: I ditched the old motor with a...   Oct 12 2009, 02:28 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 08:06 PM
