need some help with low/no idle 2.0 DJET |
TravisNeff |
Aug 2 2009, 03:28 PM
914 Guru Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region |
I just replaced my 1.7 with a 73 2.0 that has been sitting for a few years. I got it up and running yesterday but it won't idle, maybe at 200rpm's. adjusting idle speed has little effect. The engine revs easily and comes back to idle quickly.
I have all matching FI components, no vacuum leaks that I can tell. double checked my vacuum hose routing per pelican's diagram ECU idle mixture is set between factory mark and full rich (doesn't seem to make any difference other than smelling more fuel out of the exhaust) Valves adjusted and timing set. Fuel pressure is just about 30psi. I am pulling about 20hg at 1000rpm. The only issue I have is some popping once every minute or so out of the exhaust when letting the engine run about 2500rpm for a while. |
r_towle |
Aug 2 2009, 07:37 PM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
can you pull the injectors and test fire them into glass jars?
Two plugs are sooty, two plugs have not color.....makes me wonder if your FI trigger points are dirty or not firing correctly. Might be worth a validation before you pull the injectors to get them cleaned....it could be a loose ground for those injectors, it could be the trigger points, it could be the wiring harness.. Rich |
Lo-Fi Version | Time is now: 8th June 2024 - 12:54 PM |
