budman5201 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 595 Joined: 1-April 07 From: tempe, az Member No.: 7,635 ![]() |
As all you probably know, i have a ej20 turbo subaru in my car. I love it and it runs great, but now i am at the point where i want to streamline how well the system works.......
First matter of attention is the intercooler placement. I have a small water to air intercooler tucked in front of the pulley on my subaru motor. It works great, but i am getting a little too much heat soak on the aluminum tubes leading to it. I was debating an idea of putting it in the rear trunk or in the fender since placement wouldnt be a factor because its a water to air. I do like the one members ORANGE nice turbo car on 914world here with the air/air one in the back and vent in the wing..... Looking for ideas.... Attached image(s) ![]() |
charliew |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 ![]() |
Budman I really think the air to air ic in the front that you converted to water is letting the water move too fast through the awic system. The aaic has a different tube design than a radiator which is what you need. Heatsoak can be a real problem though in the engine compartment. I would like to know the water temp from the front entering the heat exchanger in the engine compartment compared to ambient temps. We know the motor is about 200f. If ambient is 100f and the air entering the intake of the turbo is 150-200f, that should be the easiest place to get the temps down. 150 is 50f over ambient. If the turbo is making 320f at high boost and you give it 50f cooler air that is less work for the ic.
You might buy a cheap electronic cooking thermometer and mount the probe in the air cleaner and check the incoming air temp. Then check the incoming water temp to the ic at the motor. 130f air temps may be the best you can do. |
Lo-Fi Version | Time is now: 12th July 2025 - 11:46 AM |
