need some help with low/no idle 2.0 DJET |
TravisNeff |
Aug 2 2009, 03:28 PM
914 Guru Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region |
I just replaced my 1.7 with a 73 2.0 that has been sitting for a few years. I got it up and running yesterday but it won't idle, maybe at 200rpm's. adjusting idle speed has little effect. The engine revs easily and comes back to idle quickly.
I have all matching FI components, no vacuum leaks that I can tell. double checked my vacuum hose routing per pelican's diagram ECU idle mixture is set between factory mark and full rich (doesn't seem to make any difference other than smelling more fuel out of the exhaust) Valves adjusted and timing set. Fuel pressure is just about 30psi. I am pulling about 20hg at 1000rpm. The only issue I have is some popping once every minute or so out of the exhaust when letting the engine run about 2500rpm for a while. |
TravisNeff |
Aug 3 2009, 11:17 PM
Ahem, it helps if you get the right injector leads into the right injectors. (I had one swapped) White ones in the front?
76-914 |
Aug 3 2009, 11:27 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,509 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
TravisNeff |
Aug 3 2009, 11:58 PM
Lo-Fi Version | Time is now: 8th June 2024 - 12:49 PM |
