> Master Cylinder Wiring Question, New 19mm unit only has one connection instead of two
Nozzle
post Aug 11 2009, 09:24 AM
As part of a stock brake overhaul, I'm replacing my old rusted 914/4 master cylinder with a new 19mm unit. Weird thing is the new sending unit only has one electrical connection instead of the two from the original one. Inside the rubber connector boot there are two brown wires, one with a white stripe and one without. Wires were disconnected by a PO long ago judging by the outstanding rust build-up on the old sending unit terminals.
Questions:
1. Which wire do I connect; the one with the stripe or without?
2. What do I lose if I run with only one sending unit wire connected?
Many thanks in advance.
Nozzle
post Aug 11 2009, 12:08 PM
Exactly what I needed to know. Thanks much to you both.
- Lo-Fi Version Time is now: 3rd July 2025 - 11:04 PM
