Rebuilding My Weber 40s ? |
kenshapiro2002 |
Aug 12 2009, 07:15 AM
Senior Member Group: Members Posts: 1,441 Joined: 23-July 09 From: Bawlmer, MD Member No.: 10,598 Region Association: MidAtlantic Region |
Can a "shade tree" mechanic like myself do this without a major cluster F*#k? I know how to label, sort and be meticulous, and how to do one at a time. On a scale of 1-10 (1 being an oil change and 10 being clutch replacement in an XKE!) whattaya think?
Ken P.S. Bought the car after it had sat for years. Rode it home from CT to MD and it ran fine for about 150 miles. Then it began to act fuel starved under any load...up hills, accelerating, etc. It gets worse day by day. I've changed fuel filter (pretty clean actually), plugs and wireset. Should I clean idle jets first...before attempting this? Any chnace I'll get the thing running again if I do this? |
jmill |
Aug 12 2009, 10:40 AM
Green Hornet Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest |
The 40 and 44 have the same carb body. The only difference is the throat size. You can use a 40 kit on a 44 but you can't use a 44 kit on a 40 because the hole in the gasket for the carb throat is too big. I want to say the last kit I bought for a set of 44's was a combo kit that had both gasket sizes and an assortment of pump diaphragms. Ask the retailer you buy it from if his kit can handle both the 40 and 44.
Lo-Fi Version | Time is now: 10th June 2024 - 04:33 PM |
