| tabs914 |
Jul 29 2009, 08:44 AM
Advertise Your Drive... ![]() ![]() Group: Members Posts: 105 Joined: 17-January 05 From: Gresham, Oregon Member No.: 3,456 Region Association: None |
Update on 10/11/09: I ditched the old motor with a new one. So all the posts to page 4 I believe are for the old motor. I do have some issues that relate to the new motor on Page 5.... (IMG:style_emoticons/default/biggrin.gif) Thanks.
OK... first thing the fuel system and harness were removed because the previous owner wanted to convert it to a duel carb set-up. So I put the FI back in. I bought a fresh battery, oil, filters and replaced the all the fuel lines plus vacuum lines. Now I want to try to start the darn thing and all I get is a "click" noise from the starter... so i jack the left side leaving the right side on the ground and put it in 5th gear. I turn the tire front the back a few times in either direction. I try to start it agian... "click". So I do the opposite side, but this time on the right i can't move the tire at all... well it will move 2-3", but thats it. Brakes are free btw. I have seen on the www that "Miricle Oil" down the plug holes will free up the pistons if they are siezed. I just dont understand that I can rotate one side and not the other. Thanks for your help... (IMG:style_emoticons/default/rolleyes.gif) Update: Found Water in the Oil - Lots! (IMG:style_emoticons/default/confused24.gif) What to do? Rebuild? Lube the hell out of it? More Mystery oil? (IMG:style_emoticons/default/blink.gif) |
| Dr Evil |
Aug 15 2009, 12:00 PM
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region
Ya, that would explain the power on the pin. That would be bad for your condenser also.
| tabs914 |
Aug 15 2009, 12:05 PM
Ya, that would explain the power on the pin. That would be bad for your condenser also. Now I have spark, but very weak... just enough to give me a tingle. So that would lead me to believe the condenser is going? Right? Thank you for your help! (IMG:style_emoticons/default/piratenanner.gif) |
tabs914 Acquired a 914-Need Your Help... She's Dead Jul 29 2009, 08:44 AM
mojorisen914 :ttiwwp: Jul 29 2009, 09:04 AM
DonnyT if you can get a socket and breaker bar onto the f... Jul 29 2009, 09:08 AM
tabs914 The car came with an extra starter... i replaced i... Jul 29 2009, 09:29 AM
Randal
The car came with an extra starter... i replaced ... Jul 29 2009, 09:34 AM
jim_hoyland Rear wheel bearings may require replacement front ... Jul 29 2009, 09:36 AM
tabs914 I can tell the resistance is internal not from the... Jul 29 2009, 09:49 AM
ericread Check your grounds. The 914 is notorious for lett... Jul 29 2009, 09:51 AM
Cupomeat Ok, on the subject of rotating the left side, but ... Jul 29 2009, 10:08 AM
Heeltoe914 Your getting allot of great tips put your trucks o... Jul 29 2009, 10:17 AM
carr914 It is not unusual for a new battery to not have a ... Jul 29 2009, 10:51 AM
ConeDodger Grounds. Jul 29 2009, 11:09 AM
Vacca Rabite Check grounds . Try a different (known good) batt... Jul 29 2009, 11:30 AM
tabs914 Thank you all... I havent tried both wheels off th... Jul 29 2009, 12:48 PM
Phoenix 914-6GT Don't miss the ground strap just above the tra... Jul 29 2009, 01:02 PM
pktzygt I've got something that stumped me for a bit. ... Jul 29 2009, 01:30 PM
tabs914
I've got something that stumped me for a bit.... Jul 29 2009, 02:14 PM
Hammy Check and clean that tranny ground and also make s... Jul 29 2009, 02:01 PM
Cupomeat Ok, good info, so that pretty much starts the prob... Jul 29 2009, 05:06 PM
Kansas 914
OK... first thing the fuel system and harness wer... Jul 29 2009, 07:27 PM
r_towle Pull the tranny out.
See if you can turn the motor... Jul 29 2009, 07:32 PM
rick 918-S A couple good ideas here.
Mike is hinting at a li... Jul 29 2009, 07:40 PM
tabs914 This is great... thank you all. OK so I get home w... Jul 30 2009, 08:42 AM
RJMII did you pull the right rear wheel and check the co... Jul 30 2009, 02:15 PM
tabs914
did you pull the right rear wheel and check the c... Jul 30 2009, 03:21 PM
Cupomeat Ok, that sounds correct to me.
if the one wheel i... Jul 30 2009, 03:37 PM
tabs914
if the one wheel ... Jul 30 2009, 04:17 PM
type2man I'm thinking the clutch disc could be stuck on... Jul 30 2009, 04:06 PM
tabs914
I'm thinking the clutch disc could be stuck o... Jul 30 2009, 04:15 PM
DonnyT You should be able to turn the engine over by hand... Jul 30 2009, 06:48 PM
DonnyT Had a problem once with a bad connection on the se... Jul 30 2009, 06:52 PM
tabs914 Found evidence of water in the oil... I removed th... Jul 31 2009, 11:00 AM
type47
Found evidence of water in the oil... I removed t... Jul 31 2009, 05:00 PM
type47 Well, you say it's been sitting 20 years and f... Jul 31 2009, 04:56 PM
r_towle water gets in for lots of reasons.
Is it alot of w... Jul 31 2009, 04:57 PM
tabs914
Is it alot of ... Jul 31 2009, 05:07 PM
r_towle can you rotate the motor?
Here is my test.
If you... Jul 31 2009, 05:08 PM
tabs914
Here is my test.
If yo... Jul 31 2009, 05:26 PM
tabs914 Not by hand Jul 31 2009, 05:09 PM
r_towle I added a bit more detail to what I mean "by ... Jul 31 2009, 05:13 PM
tabs914 Hey Rich...thank you for your time. :D I can rot... Jul 31 2009, 05:17 PM
tabs914 :Qarl: Engine finally broke loose today... now I c... Aug 4 2009, 06:59 PM
tabs914 I got it crainking :Qarl: It was the grounds... ... Aug 7 2009, 12:53 AM
McMark A little PB Blaster into the fuel pump can sometim... Aug 7 2009, 03:09 AM
Vacca Rabite If the fuel pump was seized, would it be reliable ... Aug 7 2009, 08:57 AM
kwales Sometimes it's varnish left over form dehydrat... Aug 7 2009, 09:17 AM
tabs914 Thanks for the advice... I will try it. It can... Aug 7 2009, 10:04 AM
tabs914 OK I got the pump working :Qarl: Now Im not gett... Aug 9 2009, 02:17 AM
cwpeden go to this site for FI diagnosis tips, its helped ... Aug 9 2009, 04:07 AM
tabs914
go to this site for FI diagnosis tips, its helped... Aug 11 2009, 06:25 PM
McMark I don't understand what the newest problem is.... Aug 11 2009, 09:02 PM
tabs914
I don't understand what the newest problem is... Aug 11 2009, 09:25 PM
r_towle Post a close up pic of the coil wiring.
Rich Aug 11 2009, 09:26 PM
tabs914
Rich
I... Aug 11 2009, 10:11 PM
tabs914 Here are some pics of the car... :D Aug 11 2009, 09:38 PM
tabs914 some more... Aug 11 2009, 10:06 PM
McMark Tracing backwards from the coil, with the key on:
... Aug 12 2009, 12:01 AM
tabs914
Tracing backwards from the coil, with the key on:... Aug 15 2009, 11:15 AM
tabs914 well it appears I don't have pin 8 or 9 on the... Aug 12 2009, 09:21 PM
tabs914 Here are the volt readings with the ignition on. B... Aug 15 2009, 10:25 AM
Dr Evil Was your plug messed with?
Your coil is correctly ... Aug 15 2009, 11:33 AM
tabs914 So the green heater wire shouldn't be plugged ... Aug 15 2009, 11:42 AM
Dr Evil :thumbsup: Aug 15 2009, 12:07 PM
tabs914 OK... I put a new condenser on and it seems to be ... Aug 15 2009, 03:51 PM
Dr Evil What do you mean it wont distribute? How do you kn... Aug 15 2009, 05:13 PM
tabs914 the plug wire off the coil is creating a spark, bu... Aug 15 2009, 05:38 PM
Dr Evil Ah, is the rotor installed? There is no reason oth... Aug 15 2009, 05:46 PM
tabs914 ok I think im good...I put the tester on it and it... Aug 15 2009, 05:54 PM
McMark
Mike, this'll have power if the points are cl... Aug 15 2009, 07:34 PM
Dr Evil Mark, ya, but he said the power for the blower was... Aug 15 2009, 08:30 PM
tabs914
Mark, ya, but he said the power for the blower wa... Aug 17 2009, 09:30 PM
tabs914 :bump: Aug 18 2009, 08:36 PM
tabs914 Update: I have her starting up but zero idle. What... Aug 22 2009, 08:45 PM
tabs914 OK... have a vid, the sound is terrible., but here... Aug 25 2009, 09:56 PM
McMark I'd check fuel pressure and timing first. Aug 25 2009, 11:27 PM
tabs914 ***Update*** Ditched the old motor. Oil leaks, rus... Sep 28 2009, 12:57 PM
tabs914 New Motor Pic Sep 28 2009, 01:00 PM
Cupomeat It is hard to tell, but the small threaded holes, ... Sep 28 2009, 01:28 PM
tabs914 It's off a BMW I don't have the cone on th... Sep 28 2009, 01:36 PM
Cupomeat Ah, this makes sense now.
These are the Air Injec... Sep 28 2009, 01:56 PM
tabs914
These are the Air Inje... Sep 28 2009, 01:59 PM
SLITS Whatever engine you have is a '75-'76.
I ... Sep 28 2009, 02:04 PM
tabs914 Hey if some one knows the length thread and diamet... Sep 28 2009, 02:10 PM
SLITS I'll check in in a bit if I can and measure th... Sep 28 2009, 02:17 PM
SLITS While possibly not the correct thread,
M10 X 1.25... Sep 28 2009, 02:56 PM
Thomas J Bliznik
M10 X 1.2... Oct 11 2009, 03:59 PM
tabs914 I have been working on the brakes for the last cou... Oct 11 2009, 10:35 AM
tabs914 I will elaborate what I have done so far...
1. Ch... Oct 11 2009, 11:34 AM
tabs914 :bump: Oct 11 2009, 03:03 PM
tod914 Did you reinspect your points to see if they are f... Oct 11 2009, 03:33 PM
tabs914 Points look good...I am getting spark. I checked p... Oct 11 2009, 06:13 PM
tabs914 :bump: Bump Oct 12 2009, 02:20 PM
Gint Update on 10/11/09: I ditched the old motor with a... Oct 12 2009, 02:28 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 03:09 PM |
