Another Bad Ignition Switch?, Starting woes... |
orthobiz |
Aug 16 2009, 08:00 AM
Senior Member Group: Members Posts: 1,754 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest |
I have a 2 year old ignition switch. When I first got my car, it had a bad ignition switch which I replaced when I first got the car. I haven't had problems again until this year.
I have a 1974 1.8 liter 914. Occasionally, when I turn the key, the brake lights, etc. go on in the first position, but in the START position, nothing happens. If I turn the key on and off a couple of times it will start the car. It's an intermittent problem. One time I turned it and the starter turned over but the engine wouldn't kick. It has happened when the car was hot (80 degrees here yesterday and had been running a bit) and when the car is cold. Is this an ignition switch or could it be a bad starter or solenoid or what? Thanks, Paul |
inschool |
Aug 16 2009, 12:37 PM
Newbie Group: Members Posts: 30 Joined: 3-April 09 From: Florida Member No.: 10,229 Region Association: South East States |
Ignition switch on this car is a weak point, the plastic casing has cracked twice on me since I've owned the car, inhibiting starting only. Your problem sounds very much like mine.
Lo-Fi Version | Time is now: 7th June 2024 - 05:18 AM |
