engine shroud and alternator on a /6, removal in the car |
krk |
Jan 10 2004, 05:20 PM
Senior Member Group: Members Posts: 997 Joined: 27-December 02 From: San Jose Member No.: 22 |
Folks,
Today, I'm taking advantage of the weather and trying to get to the alternator in my /6 -- which is apparently dead. Anyway, i have shop manuals which, and this is unusual, are almost useless for this. The carbs and manifolds are out. All shroud bolts (that I can find) are out. The shop manual thinks I can remove the shroud -- but there are "issues". for example, there is a wiring thing that goes through roughly the center of the shroud. (hopefully there are detachable ends behind it somehow). Are there tricks at this stage that I should be aware of? I found the secret bold behind the distributor, and the other two secret bolts accessed under the car at the back. Did I miss something? Just taking a break -- almost time to go back at it. Any BTDT appreciated of course! kim. |
krk |
Feb 10 2004, 06:29 PM
So I took a couple of hours of this afternoon -- weather is just too darn nice to let go. Finding and installing all of the shroud screws was a bit of fun. Had 4 left over at one point. Then down to 1. Got them all in finally and tightened it down.
Intake manifolds went on easy, as well as other bits of things (some trippy throttle manipulator that's likely a smog device of some kind -- vacuum line, plus two wires.) I'm hooking up the last bits of electrical and I find I didn't shoot a pic of the coil wiring. In particular, there is a brown wire on the negative side of the coil that has to go somewhere. Anyone got a clue for me? (after that, it's on to carbs/linkage/etc) kim. |
Lo-Fi Version | Time is now: 11th June 2024 - 05:36 AM |
