Coil Querie |
Coil Querie |
kenshapiro2002 |
Aug 17 2009, 01:03 PM
Senior Member Group: Members Posts: 1,441 Joined: 23-July 09 From: Bawlmer, MD Member No.: 10,598 Region Association: MidAtlantic Region |
In my ongoing quest to "fix"everything possible before I start rebuilding my webers, I figured I'd check out my coil today. I read an online article that said it's better checked out of the car, than in, and gave instructions that have me needing the resistance specs (which Haynes doesn't list).
Then, I started wondering why there was a spare (used) coil in the trunk. The Bosch coil currently in the car has two numbers on it. They are: 0 221 102 076 0 222 905 115 The spare coil lying in the trunk is: 0 221 119 009 Any insight here is appreciated as always...don't know what I'd do without y'all! |
Cap'n Krusty |
Aug 17 2009, 02:37 PM
If it fits a 928, don't use it. It's made for Bosch electronic ignition, not points or aftermarket point replacement. The Cap'n
kenshapiro2002 |
Aug 17 2009, 03:35 PM
neil30076 |
Aug 17 2009, 04:29 PM
Recovering dismantler! Group: Members Posts: 397 Joined: 12-September 06 From: San Diego ( RB) CA Member No.: 6,826 Region Association: Southwest Region |
Thanks. Any idea where to find resistance specs on the stock coil? If it fits a 928, don't use it. It's made for Bosch electronic ignition, not points or aftermarket point replacement. The Cap'n Between 1 and 15 - 3.4ohm between 1 or 15 and center 6.8kohm, hence 2000 : 1 ratio, 12v in, 24,000 volts out - and stay away from the 928 coil - that puts out around 50k - at least in my 928!!! |
Lo-Fi Version | Time is now: 2nd June 2024 - 04:55 AM |
