lightweight gears |
lightweight gears |
T H O M A S |
Aug 17 2009, 07:17 PM
Senior Member Group: Members Posts: 626 Joined: 1-August 03 From: Donaueschingen, Germany Member No.: 974 Region Association: None |
inspired by a recent threat here about lightning gears and there benefits ,i decided to give it a shoot and wire edm 1st and 2nd gear .the weight difference form stock to modified is
3rd gear .3764kg ( the lightest gear to slow down for shifting) 2nd gear was .5078kg is now .4398kg 1st gear was .6754kg is now .5468kg gears have bin cryo treated after the machining for testing the transmission will be mated to a 200hp /4 engine i let everybody know if the gears survive and if it makes a difference in shifting Attached image(s) |
Ferg |
Aug 17 2009, 09:56 PM
914 Guru Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None |
Cool!
BTW you sound normal when you type. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/bye1.gif) |
Elliot Cannon |
Aug 17 2009, 11:21 PM
914 Guru Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None |
Cool! BTW you sound normal when you type. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/bye1.gif) Naaah. He STILL sounds German. (IMG:style_emoticons/default/lol-2.gif) |
Lo-Fi Version | Time is now: 16th June 2024 - 12:13 AM |
