> Changing '95 993 Motor to OBD2 brain? Doable?
post Aug 18 2009, 12:45 AM
Resident German
My '95 993 Motor is a pre-varioram OBD1 Motor and i have been toying with the idea of updating it to OBD2.
There was, for a short time, a OBD2 brain available for the (still aircooled) 993 starting in '96 with the varioram version of the motor.
It is my understanding that besides the tubes inside the intake, the two motors are pretty much identical.
I wonder if i could get a later brain and harness and make it work with my engine.
Is there anyone out there who has tried this?
(IMG:style_emoticons/default/idea.gif) Andy
Cupomeat
post Aug 18 2009, 03:56 PM
missing my NY 914 in VA
The basic hard parts of the 95 and 96-98 993 3.6l motors are mostly identical so there should be no issues there.
Are you planning on using the vario-ram intake on the 95 993 long block? If not, why do the coversion?
Also, the ODBII exhaust has additional O2 sensors that the 95 exhaust doesn't have. You'll need to either source a later exhaust or weld in bungs.
Honestly, what will you gain with the ODBII upgrade besides the 10 hp from the Vario-Ram? I am very interested as I have a 95 993 and chose it to avoid some of the problems associated with the ODBII cars.
Very interesting idea, BTW.
post Aug 18 2009, 07:14 PM
Resident German
QUOTE(Cupomeat @ Aug 18 2009, 01:56 PM) *
Why do the coversion?
I have access to an OBD2 wireless data logger chip that uses satellites to communicate in real time to a central server that lets you stream the data into a customized Google maps webpage.
Real time position tracking, acceleration, braking, g-forces as well as any engine related data available from the brain. Rpm, ignition advance, pressures, temps, error codes etc.
And because it uses satellites there's no need to be within cell phone tower range. Works pretty much anywhere.
And best of all, it's all free of charge!
(IMG:style_emoticons/default/w00t.gif) Andy
SirAndy   Changing '95 993 Motor to OBD2 brain? Doable?   Aug 18 2009, 12:45 AM
SirAndy   Maybe i need to post this on 993world.com ... :D   Aug 18 2009, 03:36 PM
r_towle   I dont see why not. You would need to verify the v...   Aug 18 2009, 03:40 PM
Cupomeat   The basic hard parts of the 95 and 96-98 993 3.6l ...   Aug 18 2009, 03:56 PM
SirAndy   Why do the coversion? I have access to an OBD2 w...   Aug 18 2009, 07:14 PM
ghuff   Why go OBDII, why not go stand alone? What is be...   Aug 18 2009, 04:13 PM
McMark   Cool! :thumbsup:   Aug 18 2009, 07:22 PM
Chris Hamilton   I'd go with an aftermarket ECU that does OBD I...   Aug 18 2009, 07:24 PM
Cap'n Krusty   From what OBD2 stuff I deal with, I have a couple ...   Aug 18 2009, 07:39 PM
SirAndy   From what OBD2 stuff I deal with, I have a couple...   Aug 18 2009, 08:53 PM
ghuff   From what OBD2 stuff I deal with, I have a couple...   Aug 18 2009, 08:56 PM
SirAndy   What you are looking for, you need standalone. Fo...   Aug 18 2009, 09:00 PM
ghuff   [quote name='ghuff' post='1204358' date='Aug 18 2...   Aug 18 2009, 09:16 PM
SirAndy   Perhaps I can clarify it more for you if need be?...   Aug 19 2009, 01:19 AM
ghuff   Perhaps I can clarify it more for you if need be...   Aug 20 2009, 12:49 AM
r_towle   Andy, the system will be monitoring fuel, emmissi...   Aug 18 2009, 11:03 PM
SirAndy   Andy, the system will be monitoring fuel, emmiss...   Aug 19 2009, 01:23 AM
ClayPerrine   Andy.... You do realize that a varioram intake wo...   Aug 19 2009, 07:24 AM
SirAndy   Maybe it would be easier to figure out how to conv...   Aug 19 2009, 11:31 AM
Chris Hamilton   Maybe it would be easier to figure out how to con...   Aug 19 2009, 12:36 PM
r_towle   Andy, How much would and ECU/brain/harness etc co...   Aug 20 2009, 09:03 AM
SirAndy   How much would and ECU/brain/harness etc cost fro...   Aug 20 2009, 11:26 AM
SirAndy   Looks like i found a solution! :cheer: The...   Sep 3 2009, 02:14 PM
RJMII   Looks like i found a solution! :cheer: Th...   Sep 3 2009, 02:51 PM
RJMII   Wait... it by-passes the OBD2? So I could use it w...   Sep 3 2009, 03:00 PM
SirAndy   which unit do you have? Well, that's the cat...   Sep 3 2009, 03:46 PM
McMark   If you wanna install here, you're welcome...   Sep 3 2009, 03:13 PM
SirAndy   If you wanna install here, you're welcome...   Sep 3 2009, 03:40 PM
- Lo-Fi Version Time is now: 16th April 2026 - 11:42 PM
