| SirAndy |
Aug 18 2009, 12:45 AM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,473 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
My '95 993 Motor is a pre-varioram OBD1 Motor and i have been toying with the idea of updating it to OBD2.
There was, for a short time, a OBD2 brain available for the (still aircooled) 993 starting in '96 with the varioram version of the motor. It is my understanding that besides the tubes inside the intake, the two motors are pretty much identical. I wonder if i could get a later brain and harness and make it work with my engine. Is there anyone out there who has tried this? (IMG:style_emoticons/default/idea.gif) Andy |
| Cap'n Krusty |
Aug 18 2009, 07:39 PM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
From what OBD2 stuff I deal with, I have a couple of thoughts. If the system you're controlling is missing components, you may have insurmountable issues. If you're expecting full OBD2 performance out of a 1996 unit, you're NOT gonna get it. It was only slightly more sophisticated than the OBD1 unit it replaced, and lacks a LOT of functions. If you were to change the entire induction/exhaust system to go with the ECU, and you had all the other monitoring components in your car, you might have SOME of the functions you seek, but they might also be pretty basic. Later OBD2, which is pretty well developed after 12-13 years, has hundreds, probably even thousands, of functions, and would be ideal for your use. Remember, however, that there's no such thing as a free puppy, and this puppy could end up costing you a TON.
The Cap'n |
| ghuff |
Aug 18 2009, 08:56 PM
This is certainly not what I expected down here. ![]() ![]() ![]() Group: Members Posts: 849 Joined: 21-May 09 From: Bodymore Murderland Member No.: 10,389 Region Association: MidAtlantic Region |
From what OBD2 stuff I deal with, I have a couple of thoughts. If the system you're controlling is missing components, you may have insurmountable issues. If you're expecting full OBD2 performance out of a 1996 unit, you're NOT gonna get it. It was only slightly more sophisticated than the OBD1 unit it replaced, and lacks a LOT of functions. If you were to change the entire induction/exhaust system to go with the ECU, and you had all the other monitoring components in your car, you might have SOME of the functions you seek, but they might also be pretty basic. Later OBD2, which is pretty well developed after 12-13 years, has hundreds, probably even thousands, of functions, and would be ideal for your use. Remember, however, that there's no such thing as a free puppy, and this puppy could end up costing you a TON. The Cap'n Yes. Most OBDII units that allow you to monitor what is going on do not support anything that the OP mentioned. you might be able to see O2, coolant temp, throttle position, generic OBDII stuff. Like one of the scan tools that you can plug in and monitor your mileage etc. I had explored the most that a Snap-ON Modis unit would do with plain jane OBDII and was left very unimpressed. What you are looking for, you need standalone. Forget error codes, take control of the car and know what it is all doing 100% of the time. |
SirAndy Changing '95 993 Motor to OBD2 brain? Doable? Aug 18 2009, 12:45 AM
SirAndy Maybe i need to post this on 993world.com ... :D Aug 18 2009, 03:36 PM
r_towle I dont see why not.
You would need to verify the v... Aug 18 2009, 03:40 PM
Cupomeat The basic hard parts of the 95 and 96-98 993 3.6l ... Aug 18 2009, 03:56 PM
Why do the coversion?
I have access to an OBD2 w... Aug 18 2009, 07:14 PM
ghuff Why go OBDII, why not go stand alone?
What is be... Aug 18 2009, 04:13 PM
McMark Cool! :thumbsup: Aug 18 2009, 07:22 PM
Chris Hamilton I'd go with an aftermarket ECU that does OBD I... Aug 18 2009, 07:24 PM
From what OBD2 stuff I deal with, I have a couple... Aug 18 2009, 08:53 PM
What you are looking for, you need standalone. Fo... Aug 18 2009, 09:00 PM
ghuff
[quote name='ghuff' post='1204358' date='Aug 18 2... Aug 18 2009, 09:16 PM
Perhaps I can clarify it more for you if need be?... Aug 19 2009, 01:19 AM
ghuff
Perhaps I can clarify it more for you if need be... Aug 20 2009, 12:49 AM
r_towle Andy,
the system will be monitoring fuel, emmissi... Aug 18 2009, 11:03 PM
Andy,
the system will be monitoring fuel, emmiss... Aug 19 2009, 01:23 AM
ClayPerrine Andy....
You do realize that a varioram intake wo... Aug 19 2009, 07:24 AM
SirAndy Maybe it would be easier to figure out how to conv... Aug 19 2009, 11:31 AM
Chris Hamilton
Maybe it would be easier to figure out how to con... Aug 19 2009, 12:36 PM
r_towle Andy,
How much would and ECU/brain/harness etc co... Aug 20 2009, 09:03 AM
How much would and ECU/brain/harness etc cost fro... Aug 20 2009, 11:26 AM
SirAndy Looks like i found a solution! :cheer:
The... Sep 3 2009, 02:14 PM
RJMII
Th... Sep 3 2009, 02:51 PM
RJMII Wait... it by-passes the OBD2? So I could use it w... Sep 3 2009, 03:00 PM
which unit do you have?
Well, that's the cat... Sep 3 2009, 03:46 PM
McMark If you wanna install here, you're welcome... Sep 3 2009, 03:13 PM
If you wanna install here, you're welcome... Sep 3 2009, 03:40 PM![]() ![]() |
Lo-Fi Version | Time is now: 17th April 2026 - 01:01 AM |
