> Changing '95 993 Motor to OBD2 brain? Doable?
post Aug 18 2009, 12:45 AM
Resident German
My '95 993 Motor is a pre-varioram OBD1 Motor and i have been toying with the idea of updating it to OBD2.
There was, for a short time, a OBD2 brain available for the (still aircooled) 993 starting in '96 with the varioram version of the motor.
It is my understanding that besides the tubes inside the intake, the two motors are pretty much identical.
I wonder if i could get a later brain and harness and make it work with my engine.
Is there anyone out there who has tried this?
(IMG:style_emoticons/default/idea.gif) Andy
post Aug 19 2009, 11:31 AM
Resident German
Maybe it would be easier to figure out how to convert the engine output from OBD1 to OBD2 and feed that into the data logger ... (IMG:style_emoticons/default/type.gif)
Chris Hamilton
post Aug 19 2009, 12:36 PM
QUOTE(SirAndy @ Aug 19 2009, 10:31 AM) *
That's why I suggest an aftermarket ECU. That would probably be a bunch more configurable for outputs. I remember hearing something about the haltechs that do CANBUS being able to output OBDII signals.
You might even pick up a couple extra horsepressures while you're at it.
SirAndy   Changing '95 993 Motor to OBD2 brain? Doable?   Aug 18 2009, 12:45 AM
SirAndy   Maybe i need to post this on 993world.com ... :D   Aug 18 2009, 03:36 PM
r_towle   I dont see why not. You would need to verify the v...   Aug 18 2009, 03:40 PM
Cupomeat   The basic hard parts of the 95 and 96-98 993 3.6l ...   Aug 18 2009, 03:56 PM
SirAndy   Why do the coversion? I have access to an OBD2 w...   Aug 18 2009, 07:14 PM
ghuff   Why go OBDII, why not go stand alone? What is be...   Aug 18 2009, 04:13 PM
McMark   Cool! :thumbsup:   Aug 18 2009, 07:22 PM
Chris Hamilton   I'd go with an aftermarket ECU that does OBD I...   Aug 18 2009, 07:24 PM
Cap'n Krusty   From what OBD2 stuff I deal with, I have a couple ...   Aug 18 2009, 07:39 PM
SirAndy   From what OBD2 stuff I deal with, I have a couple...   Aug 18 2009, 08:53 PM
ghuff   From what OBD2 stuff I deal with, I have a couple...   Aug 18 2009, 08:56 PM
SirAndy   What you are looking for, you need standalone. Fo...   Aug 18 2009, 09:00 PM
ghuff   [quote name='ghuff' post='1204358' date='Aug 18 2...   Aug 18 2009, 09:16 PM
SirAndy   Perhaps I can clarify it more for you if need be?...   Aug 19 2009, 01:19 AM
ghuff   Perhaps I can clarify it more for you if need be...   Aug 20 2009, 12:49 AM
r_towle   Andy, the system will be monitoring fuel, emmissi...   Aug 18 2009, 11:03 PM
SirAndy   Andy, the system will be monitoring fuel, emmiss...   Aug 19 2009, 01:23 AM
ClayPerrine   Andy.... You do realize that a varioram intake wo...   Aug 19 2009, 07:24 AM
SirAndy   Maybe it would be easier to figure out how to conv...   Aug 19 2009, 11:31 AM
Chris Hamilton   Maybe it would be easier to figure out how to con...   Aug 19 2009, 12:36 PM
r_towle   Andy, How much would and ECU/brain/harness etc co...   Aug 20 2009, 09:03 AM
SirAndy   How much would and ECU/brain/harness etc cost fro...   Aug 20 2009, 11:26 AM
SirAndy   Looks like i found a solution! :cheer: The...   Sep 3 2009, 02:14 PM
RJMII   Looks like i found a solution! :cheer: Th...   Sep 3 2009, 02:51 PM
RJMII   Wait... it by-passes the OBD2? So I could use it w...   Sep 3 2009, 03:00 PM
SirAndy   which unit do you have? Well, that's the cat...   Sep 3 2009, 03:46 PM
McMark   If you wanna install here, you're welcome...   Sep 3 2009, 03:13 PM
SirAndy   If you wanna install here, you're welcome...   Sep 3 2009, 03:40 PM
- Lo-Fi Version Time is now: 16th April 2026 - 11:42 PM
