OT: more "heavy metal" in the garage !!!, Bridgeport CNC ;) |
Mueller |
Feb 11 2004, 12:01 AM
Well, i finally moved up in the world and picked up a "real" mill to add to my home shop......2200+lbs of cold steel/iron (IMG:style_emoticons/default/smash.gif)
I had gotten out bid by hundreds of dollars and at the last minute, the highest bidder retracted his bid and I won it (IMG:style_emoticons/default/wink.gif) The mill looks perfect (not at home yet, I inspected it at the shop), the biggest challange will be figureing out how to use the darn thing since it has no provisions to manually move any of the axis and the CNC controller is pretty ancient...... I'll also have to convert the main spindle motor from 3 phase to 2 phase or use a static or rotary converter........ (IMG:style_emoticons/default/confused24.gif) My workshop pad should be going in this weekend, originally I was only going to pour it 4" thick, now i think I'll make it 6" thick with more rebar......... |
fiid |
Feb 11 2004, 01:42 AM
Turbo Megasquirted Subaru Member Group: Members Posts: 2,827 Joined: 7-April 03 From: San Francisco, CA Member No.: 530 Region Association: Northern California |
QUOTE(Mueller @ Feb 10 2004, 10:01 PM) The mill looks perfect (not at home yet, I inspected it at the shop), the biggest challange will be figureing out how to use the darn thing since it has no provisions to manually move any of the axis and the CNC controller is pretty ancient........ uhh - megasquirt man! (IMG:style_emoticons/default/chairfall.gif) My brother-in-law makes components to do stepper motor control and other stuff from USB or serial. http://www.makingthings.com I don't think anyone has used the stuff to do CNC control, (I want to use it to do track datalogging - which noone has done either), but it is easy to use and makes the whole interfacing thing very easy. |
Lo-Fi Version | Time is now: 6th June 2024 - 01:46 AM |
